#71
Re: Is my MONSTER 12-core 3,33GHz Mac Pro underperforming on low buffer sizes?
Or keep both pcie ssd's in when using yosemite of a spinner, record to both simultaneously, and perhaps it's the case of both of them using too much pci bandwidth and taking it from the HDN card. This way you could do that test without installing yosemite on the pcie ssd. Or perhaps put a large sample library on one of them and stream some samples from it as you are recording to the spinner. Just try make sure both PCIE ssd are in operation whilst you are using yosemite from the spinner.. yet it begs to wonder.. you say you don't think they had anything to do with it, but both situations that are giving you success, is with the OS *NOT* on the pcie ssd but rather in the sata bay. So we have gotten to the point where it can only be one of two things.. 1) Sierra and recent version PT issue with your particular setup 2) PCIE ssd issue or maybe a possible third scenario, where it's a combination of sierra and something, like maybe the graphics. I'll be interested to see when it's finally sorted for good, but in the meantime, it's marvellous that you can record at low latency with that very same computer using a different hardware combination, and pretty much confirms that the chips are not too slow to do such a thing. I am bowing out of this, as i will no longer put up with musicman's hostility.. i made him an offer to stop talking to me and quoting me, to prove i wanted no issue, but he can't stop. This is proof to me that he just likes interacting with me and trying to get me to reply to him.. So, i'm out. He wins. It's amazing when i have put it on the table that i want literally nothing to do with someone, and he is trying to force me into his life by quoting me continually. I mean, come on. I hope you work it out so it works for you in sierra, with your pcie SSD's and all is well. Truly.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#72
I’m migrating the Yosemite install to an SSD on the PCIe adapter as we speak, so we will soon have the answer. If things are still good after this move I’d say we should be able to put the PCIe SSD theory to rest - on this system at least.
Jonas Kroon SAGA Studio Oslo, Norway |
#73
So if yosemite and PT 12.8.1 works on the pcie ssd config you had prior with sierra, then it's definitely a sierra issue with your computer. Maybe because the graphics system of the OS had some changes in el capitan and up, and it's having some issues with your 680. It could be anything. But as i said above, just a courtesy since i saw you quote me, but i'm out. Best of luck.. I'll check it again in a week in the background and hopefully all sorted for you. PS to make it a fair test, make sure both pci SSD are working like with the sierra install.. os and pro tools on pcie ssd and audio drive on other pcie SSD. Cheers, I really do want it to just work for you once and for all.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. Last edited by TNM; 02-13-2018 at 11:20 AM. Reason: spelling only |
#74
UPDATE:
So I migrated Yosemite onto an SSD drive and put it into a SATA II connector in the optical bay. Recording in Pro Tools worked perfectly. Then I tried connecting it to one of the PCIe adapters instead. Boot times were reduced from 110 to 45 seconds and I was able to measure higher read and write speeds. Apart from that I noticed no difference. Recording in Pro Tools still worked perfectly. So I think we can safely say that it wasn't a PCIe adapter problem this time. I suggest there might a compatibility issue with Sierra on this computer. However, I'm not going to investigate any further. I'm keeping this Yosemite install. Pro Tools 12 works like a charm now and I need to get back to recording and mixing music. I might purchase a new Mac Pro in a year or two if Apple decides to release a new model, but I'm happy for now. Thank you all for sharing your knowledge and experience in this thread!
#75
#76
No compatibility issues so far. Everything seems stable. Please note that I was advised to stay on Pro Tools 12.8.1, as there is allegedly a GUI lag issue starting with Pro Tools 12.8.2 on some of these older machines.
#77
Hi there Kroon, I wanted to chime in for you and maybe others;
as for several weeks I have been chasing down similar issues with a similar machine. Mine is a Westmere 3.46 12 core originally running PT 10 HD on OS X 10.8.5 and then switching to an HDX running 12.4 HD on OS X 10.12. And was getting streaming errors with the same dialogue you mentioned in your original post. Like you, went through all the optimizations; ended up upgrading to 10.12.6 and HD 2018.1 and was still getting stoppages. Did multiple digitests with and without hardware and PCI cards, also swapping of video cards; put the playback engine into aggregate, and played with "ignore errors" suppression enabled. Found out there was specific issues with Phoenix Verb and AmpliTube 4. Also found out there are PT performance issues for many Mac computers, typically 2010 to 2012 models. (Also watched that very informative video- CPU Performance vs. Real-Time Performance in Digital Audio Workstations; mentioned earlier in the thread which should probably get a sticky around here!) So what finally stopped the errors for me, was going to Xcode Instruments and disabling hyperthreading, which on a monster machine such as ours and with the HDX card means it's still idling most of the time… e for the record studios
ihatetyping Last edited by elicious; 02-15-2018 at 05:20 AM. |
#78
Thank you, elicious, for that insight.
I might try disabling hyperthreading myself, out of curiosity, as I have heard of a few people now who've had success with that. I'm glad you solved the problems with your system.
#79
After months and months of chasing wind for answers on this topic, disabling hyperthreading is the only thing that helped. I say helped because I still received CPU errors, but they were less frequent.
#80
I’m encountering the same issue on a simliar machine (specs below) and PT HD Native as Kroon is his original post. I have two 2010 Mac Pro 5,1 machines (1 stock, 1 upgraded) and borh have had the same issue with graphics related glitches on PT 12.8.3 and 2018.1 on Sierra 12.12.6 when attempting to record 24 tracks.
Scrolling around or even viewing the drawing the waveforms for the tracks being recorded seems to make the CPU fluctuate drastically. Scrolling down where the waveforms are being drawn while recording are no longer visible or minimizing/hiding the edit window reduces the cpu fluctuations to almost zero. At a buffer of 256 I can track with no issues and lots of plugins. At a buffer of 64 with no plugins any screen movement or waveform drawing (from the tracks being recorded) causes this issue, even at 44.1. It doesn’t seem to matter if the tracks have blank audio or are drawing typical waveforms from recording audio. I also have the system drive on a Samsung 850 512gb SSD on an OWC pcie accelsior card. I’ve tried both a stock Radeon 5770 and an Nvidia Quadro 4000 as my video card with the same results. I have an old system HDD with Yosemite and PT 12.7.1 on it. I just tried it and while the mix window meters aren’t a fluid as they are on Sierra with 12.8.3 and 2018.1, the cpu spikes don’t occur unless I do a ridiculous amount of constantly scrolling around the edit window like a madman. Even then, they are nothing like they were on Sierra with the later versions of pro tools. I’m going to try 12.8.1 on this system and see if the meters run any smoother. Has anyone tried 2018.1 with High Sierra? Do the same problems occur? System specs: Sierra 10.12.6 Pro Tools 2018.1 HD Native 2010 Mac Pro 5,1 3.46ghz 12 core 128gb RAM Radeon 5770 (Also tried Nvidia Quadro 4000) Second system: Sierra 10.12.6 Pro Tools 2018.1 HD Native 2010 Mac Pro 5,1 2.4ghz 8 core 32gb RAM Radeon 5770 All PT optimizations followed to the letter on both systems. |
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere | Detlef Brockmann | Pro Tools TDM Systems (Mac) | 9 | 02-21-2020 10:39 AM |
8 GB RAM in MacPro 6 core 3.33GHZ | songman | Pro Tools TDM Systems (Mac) | 1 | 12-07-2011 04:05 AM |
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere | Detlef Brockmann | macOS | 4 | 02-18-2011 07:08 PM |
Mac Pro 3.33Ghz 6 core Westmere & VE PRO | johnpaulgeorgeringo | Pro Tools TDM Systems (Mac) | 36 | 01-02-2011 09:35 AM |
2010 mac pro 2.4Ghz 8 core vs 3.33Ghz 6 core | edadema | Pro Tools TDM Systems (Mac) | 32 | 09-07-2010 07:36 AM |
