Stereo vs. Mono D-Verb
I'm editing some recordings of solo piano I made with a single mic. I notice that there is a substantial difference in the stereo image if I insert the D-Verb into the mono track or into the stereo master fader. I clearly prefer the results obtained by putting the D-Verb in the master fader, since it gives a much more spacious sound.
Does anyone have any idea of how the spacious sound is created? Is it just some sort of random difference in the two reverb signals? John Link |
Re: Stereo vs. Mono D-Verb
When you create the D-Verb on the mono track, are you selecting (from your plug in list)
the mono version or the mono in/stereo out version? Since your master is stereo, you will always get a stereo D-Verb, but it sounds like you're putting a mono D-Verb on your mono track. I would create a mono Aux track, and put a mono in/stereo out D-Verb (or other reverb plug in-there are better sounding ones) on the aux. Set the input to the aux to be a bus, then, on your piano track, create a mono Send to the same bus and play with the send level to get the right amount of reverb. Just make sure that the Mix control on the reverb is set to 100% wet.
When you once describe a venture as a holy war, you surrender all capacity to judge honest alternatives. -James A. Michener |
Yup, I had chosen the mono reverb. I didn't realize that (mono/stereo) referred to mono-in/stereo-out. Thanks for the info.
So does anyone know just how a stereo reverb gives such a spacious sound? John Link |
The left and right processing channels are "tuned" differently so as not to correlate. Some plugs (or reverb boxes) do that better, some are worse.
Z |
making mono track into stereo or double mono in PT7LE | VeganMuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-02-2012 05:36 AM |
A question about mono/stereo plug ins on mono tracks. | rockguitarist1255 | Pro Tools 10 | 2 | 12-24-2011 07:33 PM |
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-14-2010 09:01 AM |
Mono/stereo Stereo mono..... What happen here ? | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-18-2004 09:28 AM |
stereo file to mono and mono too stereo ? | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-19-2003 07:52 PM |
