Can't get 2.5.6. to work :-(
Hi forum,
I'm trying to get 2.5.6. to work but the workstation will not attach to the EuControl software. When I revert to 2.5.5. all is well and EuCon finds and attaches the workstation just fine (apart from PT 9 not working with this release....). I have tried this on two different machines running 10.6.4. (System language is German) I have Mix, Transport and Control hooked up via a gigabit switch. Ollie |
Re: Can't get 2.5.6. to work :-(
I dont have PT9 Installed but i also had to rollback to 2.5.5 once nothing but nothing worked with 2.5.6....
PT L e 8.0.4cs4 and Nuendo 5.1(with EuCon licence) and a single MCMix on 10.6.4._connected to EnetP1 Avid:Any feedback_comments? |
All of a sudden, I'm in the same boat as you Ollie. The big difference is that I had it working last night with PT9, EuCon 2.5.6 and the firmware updated in both my MC Mix and MC Transport. Hardly any fuss at all.
When I fired everything up this morning, I cannot get either Artist Series device to acknowledge PT9 or vice versa. The only change that I'm aware of was a shut-down for the night. I've re-installed EuCon AND PT9 twice with no joy. HELP! PLEASE! NL |
First...
* Installed 2.5.6 * Then I deleted ALL Eucon pref. files in BOTH Libraries, (Main + User lib) Then... * I deleted ALL ProTools prefs, * I re-installed ProTools 9, * I repaired permissions. * Restart, and finally...Everything work as it should ! Hope this helps ... G |
Gemylon, that was the ticket! I'm operational again!
I'd killed the EuCon .plist files in the main Library but not in the User Library previously. Wow! Many thanks! NL |
I'm going to try that tomorrow.
Thanks
MacPro 2.8 8core|PT 11|3xUAD-2|2xMC MIX Thermionic Phoenix Mastering Plus|Manley Massive Passive|API 2500|Distressor EL8-X|Summit TLA100 |
That's got it for me too!
Deleting the preferences. Why didn't I think of that?!!!
Studio: Mac Pro Trash Can 2.7 Ghz, 32Gb RAM, Sonett xMac Pro Server, HDX 22.12, S6 M10 24 Fader, Rednet 5,1 and 4 Live: MBP 16" M1 Max i7 32Gb RAM, |
Now it works.
I didn't repair permissions and didn't install Protools again. Just trash the preferences and install it again.
Thanks everyone, I've got it working now.
Well, I had it working a while back...
Now, I am having some main issues with connecting to my Artist series. I have a MC Control and 3 MC Mix. When opening the EuControl Settings panel, most of the time there is no Workstation in there. And if there is, and I try to attach it, it just disappear. I have tried everything. I ave trashed Preferences in both Libraries, and both Euphonix and ProTools. I have installed both EuControl and ProTools over agin, but nothing helps. I have also done the Network Connections procedure form scratch again. I am using MacOSX 10.6.5, ProTools 9, and EuControl 2.5.6 Running a MacPro with 18 GB RAM. So any idea where to go from here ? G |
Audio Suite plugins that work in 10, do they work in 11? | David Sandwisch | Windows | 1 | 08-10-2013 08:14 PM |
The plugs that WORK and DON'T WORK on 7.0 | The Mink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 02-10-2006 10:12 PM |
New Mic won't work | DougSt.Louis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-12-2002 09:06 AM |
How does Direct Connect work?? (Does it work well??) | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-18-2001 08:13 AM |
