Old 01-27-2004, 11:35 AM
keysmia keysmia is offline
Default adding to an existing audio track
Hi all, I can't seem to fiqure this out. I am working on an audio track from a cd and want to lock in the tempo and add to the existing track. How do you keep the track from drifting. I know the tempo is around 137. It lines up ok in grid mode then it drifts. Could this be the recording ? From a dat maybe? What is the procedure? I never could get identify beat working properly. Please Help
Old 01-27-2004, 12:37 PM
cwhite771 cwhite771 is offline
Default Re: adding to an existing audio track
Depends on how the material was recorded (digital or analog), whether it was locked to a tempo (if they used a click track), or even how accurate the equipment used to record is.
You could use something like Ableton Live to adjust and lock in the tempo.
c
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff.
Old 01-27-2004, 01:51 PM
Tubz Tubz is offline
If "Identify Beat" / Edit, can't set the exact time, it's not played to a click.
adding drums on an existing midi track aehn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2010 10:20 AM
Preventing Existing Audio From Recording on another track, MITD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-08-2008 03:20 PM
Adding EA to existing 7.3 sessions? lwilliam Pro Tools TDM Systems (Mac) 7 11-12-2007 09:31 AM
Is there a shortcut for adding or deleting tracks from existing track groups? melodymanpop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-13-2001 11:31 PM
