INSTRUMENT track PROBLEM
I created 8 instrument tracks, loaded hypersonic on each insert, and then assigned each track to the respective channels 1 thru 8. I can record midi and hear it all......but All of the sounds coming from tracks 2-8 goes through the first track. How do i get the activity to be in each respective track? thanks.
Intel [email protected] overclocked Asus P5B Deluxe wifi 4 gigs OCZ DDR2 PC2-8500 ram Nvidia 7600GT 8.0 on Vista Ultimate |
Re: INSTRUMENT track PROBLEM
Make sure that the MIDI output of each Instrument track is being routed to the Proper instance of your VI.
Also, Hypersonic one, or Hypersonic 2? Are you wrapping it? Obviously, you must be unless you are using Rewire... Oh wait, that could be the issue. Are you insterting multiple instances of the Hypersonic Rewire plugin? Does hypersonic have individual audio outputs?
It does. Try setting the audio outputs as directed starting on page 90 of the Hypersonic manual, and ensure that your separate instruments in Hypersonic are set to those individual audio outputs (page 56).
Instrument Track Input problem | typhy | macOS | 1 | 10-04-2011 09:12 AM |
Problem Converting Instrument Track to Audio Track | Gorbies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-02-2009 09:11 PM |
Instrument Track problem | TheWillies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-14-2009 10:31 AM |
Pro Tools 8 Instrument Track Problem... Uh Oh | M2E | Pro Tools TDM Systems (Mac) | 14 | 12-17-2008 05:48 PM |
Instrument track problem | stanjank | MIDI | 4 | 11-13-2008 10:57 AM |
