Old 01-08-2009, 11:20 AM
glankrudolph glankrudolph is offline
Default Mbox2Pro compatibility? MacBook Pro?
Is the MBox2pro with ProTools LE 7.4 compatible with a MacBook Pro running OS 10.5?
Old 01-08-2009, 11:24 AM
Muzick Muzick is offline
Default Re: Mbox2Pro compatibility? MacBook Pro?
I have recently purchased a Macbook Pro 10.5.5 and have been using it quite successfully with a Mbox 2 Pro.
Started with PT LE 7.4 and upgraded to 8.0 with no problem.
I recommend am expresscard with additional FW400 ports. Run the audio hard drive from that and get a FW800 to FW400 adapter and run the Mbox 2 Pro off the Macbook Pro FW800 port.
Old 01-08-2009, 02:22 PM
temujin temujin is offline
Same here and all is working great so far but as I'm quite a nubie I haven't done much advanced or big projects yet... but it certainly does work
At the moment I've recorded to the system drive because I'm still waiting for my expresscard but I couldn't wait to do music! It didn't work when it was daisy chained: mbox2pro connected to ext hd then into MBP but it does work if its: ext hd then mbox2pro then MBP... but I know this is not the optimum configuration. Expresscard is probably the best way to go...
Old 01-08-2009, 02:35 PM
Unless I'm mistaken, OSX 10.5 (Leopard) requires Protools 7.4.2 and not Protools 7.4
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.13.6 running Protools 2018.7.0
Old 01-08-2009, 03:37 PM
AH, good eyes Obsidian.
I should correct my above statement that I did go from 7.4.2 to 8.0 on the Macbook Pro.
I dont know about 7.4
Old 01-09-2009, 08:42 AM
Great - thanks for the help - time to max out another credit card! :)
Pt 8 le and mbox2pro compatibility hardware abikambic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2010 07:03 PM
Macbook not always recognizing mbox2pro? volkgti90 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-19-2009 06:52 PM
laptop compatibility with mbox2pro le ranas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-13-2009 12:39 PM
MBOX2PRO and MACBOOK 2.4Ghz 13,3" compatibility akli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-18-2008 06:08 AM
Plug-ins, MacBook and Mbox2PRO Hemluth General Discussion 2 05-31-2008 04:16 AM
