XMON problem
Hi All,
We have a customer who recently had a XMON problem. Below are the details: System Setup: PPC G5 Dual 2.3GHz Mac OS X 10.5.5 Pro tools HD 7.4.2cs4 D-Command Firmware 7.4.2.109 XMON Firmware 11 Problems: The XMON has been automatically muting its monitor section, it appears on the D-Command status "XMON OFF". Then, we tried to release the mute button on the D-Command, but still there is no audio out from the speaker although Pro Tools is running with audio signals on Master Fader. This happens intermittently, at intervals from a few seconds to a few minutes, regardless of whether Pro Tools is running. Sometimes, you can wiggle the volume knob then release the mute button again to be able to hear the audio again. But sometimes it does not work, hence we did turn power OFF and ON again on the XMON unit. Then, we get back to normal again, the D-Command status shows "XMON ON" and we can hear the audio from the speakers. But this is only remain for a while, it leads to a situation following a self mute (without pressing mute), where the D-command indicates that it is muted but audio is coming out of the monitors and we cannot change the volume adjustment via the volume knob or either change the speaker input selection (the volume and the speaker input selection are remain to our choice before the self mute occurs), or alternatively (following a mute press but not adjustment) where the D-command indicates it is unmuted but no audio emanates from the monitors. We have also checked that the XMON cable run properly without hard bending. Finally, we tested it with a new XMON unit at the same time, and it runs well, it didn't mute automatically. Anyone had this problem before? Look forward to receive all of your advise.. Cheers, Sandika |
Re: XMON problem
Hi Sandika,
I have seen this issue before. You need to get the bad XMON swapped out for a new one. Get in touch with Digidesign Technical support in your region and they'll help out. |
Re: XMON problem
Hi Buccanears,
Thank you for your reply.. |
Re: XMON problem
This has happened to me today too!
Mac 2x2.93 GHz Quad-Core Intel Xenon 32 GB 1066 MHz DDR3 Protools HDX Logic Pro Euphonix System 5 MC UAD-2 OCTO ULTIMATE Komplete 8 Ultimate Ivory LASS Lots of other cool stuff. Now all I need is to learn how to work it all! |
Re: XMON problem
Re: XMON problem
this may seem obvious...but i was having a similar problem with my xmon; randomly muting, xmon off messages, etc.
after moving all of the wires, the connectors, reseating everything and restarting (which sometime fixed the problem) i removed the xmon from the rack, it has been sitting on top of the rack, with unobstructed air flow. i haven't had a problem since. just a thought (sometimes, it's the simple things...of course, most of us technical people have a tendency to forget this :) |
Re: XMON problem
My Xmon problem was solved.
Instead of connecting the power to Furman power distributor, I now connected Xmon power cord to one of the free wall plugs. It is working without any problem now. |
Re: XMON problem
Thanks Wayne
Leaving some empty space around the Xmon fixed the problem for 6 month The muting problem came back yesterday and mine is also plugged into a Furman P.S. I also changed the power cable. Let see how long it'll run,10 mn so far i have hope Francois
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1 - D-command 24- Trinnov Dmon6 |
Re: XMON problem
ouch! in only lasted 1 hour
time to open the box and dust it like Craig suggested
Need XMON help | AINSLIE | ICON & C|24 | 9 | 05-31-2012 11:51 PM |
XMON by itself? | melodydetective | ICON & C|24 | 1 | 05-13-2010 01:45 PM |
Xmon mod?? | mtung | ICON & C|24 | 0 | 10-01-2009 05:16 AM |
Could a problem with my XMON have blown my tweeters? | Bambison | ICON & C|24 | 4 | 07-13-2009 03:37 PM |
XMON for your DAW | Mike Landolt | General Discussion | 1 | 04-13-2006 03:04 PM |
