Rack 002 & 002 Mixer working together?
Hey what's up, I'm new at this so I can use a lot of help.
I'm a drummer, I have the 002 rack working with Pro Tools LE 7 in Windows XP, I recently bought the 002 mixer but I'm not sure how to make them work together. Can this 2 (rack & mixer) work together with PT LE 7? If yes, how do I connect them? Or should I keep only the mixer to record? Thanks everyone! |
Re: Rack 002 & 002 Mixer working together?
You cannot use them at the same time on the same system.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
I see, would you consider using the mixer is better than using the rack?
1 more question, sometimes when I'm playing back the tracks I just recorded (while using the rack) the sound stops, I can see in my monitor that the tracks are playing but there's no sound, any advice on this? Thank you so much. |
oops, I forgot to ask...
Does the mixer and rack serve to the same purpose? Or is 1 of them meant to do something and the other a different thing? Please excuse my ignorance but -as you can see- I'm a beginner. |
The 002R serves the same purpose as the console version, but without the obvious control surface hardware. It's really up to you which you prefer.
What are you using for monitors? Check cables would be the first thing to do I think.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Thanks for the answers, I think I'll just keep the console.
For monitors I use 2 RP5 Rockit 5, I checked the cables and everything seems to be in right order, usually the sound goes out when I'm using the guitar rig plug-in, could this be the cause? Thanks. |
Plugins from time to time need to be updated to remain compatible with the version of Pro Tools you are running (or Vice-Versa). Whilst it may not be absolutely necessary, if I were in your situation I would upgrade to PT8.0 then it's free to 8.05. You could probably pick it up cheap on eBay .
Sell both and get a 003 Console. They are are easy to find cheap now priced from $650-950 and would upgrade your software and hardware. I have owned 2-002 Consoles and 1- 002R and they still scared me until the day they were gone.
URBAN MUSIC- (Hip Hop and R&B) |
Put the console in standalone mode not connected to ptls, use 002r as the ptls interface.
Now connect the console via ADAT to the 002r. The console will pass all inbound audio to the adat connection pre fader. this will pass to the adat on the 002r and bang 16 channels. I think its will only go to 44.1, but its been a very long time since ive done that. Also have to set the clock on the console to external, or vice versa with the 002r.
Mac Pro, Snow PT 10HD,Sequoia, Reaper W7/64, PT 9HD,Sequoia, Reaper 192 HD, HD-N, 002C BLA, BLA AGB,Autuer,Lucid, MicroCLock, Pultec, UA, Sebatron, Focusrite, Trident,API, A-Designs, Purple Audio
Eleven rack as FX through mixer | Sf Audio | Eleven Rack | 7 | 07-22-2012 11:17 PM |
003 rack to mixer. | drummer1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-27-2012 09:08 PM |
Connecting 003 rack to mixer | drummer1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-17-2007 10:41 PM |
Connecting a Dj Mixer to the 002 rack | canicypher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-16-2006 06:33 PM |
MIxer + 001 rack? | toekneebullard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-22-2005 01:59 PM |
