Old 01-27-2005, 08:06 AM
SNJ SNJ is offline
Default I CANT REMOVE PT 6.1.1
I have it on an XP SP1 machine, I have already erased the Digidesign folder from "Program Files" manually, but it still appears on Add & Remove Programs . When I click on "Change/Remove" it doesnt do anything, ITS ALWAYS THERE .
What can I do to make it dissappear ? please ..
thanx
Old 01-27-2005, 08:22 AM
Bazzle Bazzle is offline
Default Re: I CANT REMOVE PT 6.1.1
You should have used ADD/REMOVE programs to uninstall it in the first place..You could reinstall it, and then use ADD/REMOVE programs to uninstall it..That would be the simplest method.
Bazzle
Old 01-27-2005, 09:02 AM
GothicV GothicV is offline
man oh man did you mess it up. I hate it when people don't just uninstall crap, it buggers up your registry.
Old 01-27-2005, 09:47 AM
SumOdRsn SumOdRsn is offline
You'll have to open Regedit.exe, the traverse to HKey_Local_Machine\Software\Microsoft\Windows\Curr entVersion\Uninstall and delete the registry key where DisplayName is the name of the program that is listed. If you are not comfortable manually removing items from the registry, then don't do it.
Otherwise you can reinstall the program and uninstall it using add/remove.
Old 01-27-2005, 11:36 PM
SNJ SNJ is offline
OK, its done. I have done an upgrade to 6.4 and its running well.
Thanx a lot
Please help... how to remove vox from .wav?? superpenguin79 General Discussion 10 03-04-2013 12:34 AM
Does remove PT - remove projects too? Andy Gerome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-29-2008 11:29 AM
Add/ Remove Programs will not Remove Pro Tools powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-07-2005 02:48 PM
Remove OSX? pag113 Pro Tools TDM Systems (Mac) 3 10-14-2002 05:36 AM
Do I need to remove it. stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-19-2002 11:01 PM
