Old 06-20-2020, 09:26 AM
Mishabou Mishabou is offline
Default Room measurement with REW
Hi all,
I'm new to REW and have a few questions.
My mix room is equipped with PT Ultimate and Avid MTRX with Pro Mon. My REW rig is a portable Windows 10 laptop with the Roland Octapre soundcard. My monitors are JBL 708i for L-C-R and 705i for surrounds. Mics are Beyer MM1 with calibration files for 90 and 180 degrees position. I use 90 degree, mic is facing up (ceiling).
In order to have the Pink/Sweep from REW played on my monitors, i have:
- Output 5 from Octapre soundcard plugged into input 5 on MTRX
- In Protools, on a mono audio channel, i have input assigned to input 5 of MTRX and Output is set to each of the respective surround channel as i take my measurement (L-R-C-Lfe-Ls-Rs).
As recommended in the manual, Pink volume is set to 75dB via SPL meter.
I usually take 4 measurements (mic placed at 4 different locations in the mix room) per channel, so 24 total.
Will the set up above yield proper measurements ?
Does REW offer mutli microphones measurements ?
Thanks
HTML code is On
position of measurement for calibration vudoo Post - Surround - Video 3 01-31-2017 01:16 PM
Audio Analysis and Measurement FifthDoctor General Discussion 10 01-13-2013 03:33 PM
LIP SYNC (measurement) Eric Seaberg Post - Surround - Video 2 05-26-2008 06:25 PM
Audio measurement software Gunnar Hellquist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-10-2004 04:28 PM
Rack Space Measurement! saeblee General Discussion 3 01-17-2002 09:15 AM
