Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 05-14-2020, 05:21 PM
Mishabou Mishabou is offline
Default Logic Pro Appset not working
When using LPX 10.5, none of the softkeys work, they are blank. Tried loading the LogicX appset, still nothing. Any idea ?
I'm using the latest WS 20.1.0.5 on Catalina.
Thanks
Old 05-15-2020, 09:48 AM
EddieJones's Avatar
Default Re: Logic Pro Appset not working
You should just be able to load them. Send me your Appset in a PM and I can try and load here
Old 05-15-2020, 09:55 AM
Hi Eddie,
I loaded the LogicProX Appset that was included in the S6 Master Module Install 20.1
Old 05-15-2020, 10:05 AM
EddieJones's Avatar
I'm being told we don't include one. Did you add any of your own softkeys ?
Old 05-15-2020, 10:23 AM
No i did not add any of my Softkeys.
Baically, i installed WS 3.5 when i first bought the S6 years ago, then installed WS 20.1 two months ago.
When i hit Load i see one LogicProX Appset and that's the one i used. Are you saying that LPX Appset that comes with the 20.1 installer does not include any softkeys ?
Old 05-15-2020, 10:26 AM
EddieJones's Avatar
Did you see any softkeys on the surface with the older version of Logic ?
Old 05-15-2020, 10:31 AM
Sorry i can't remember if the softkeys were present on the older version of LPX.
I've been on 10.5 since it came out.
Old 05-15-2020, 10:32 AM
If you're on an older version of LPX, can you load the Appset from 20.1 and see if the Softkeys are there ?
Old 05-15-2020, 11:45 AM
EddieJones's Avatar
We don't ship an Appset so unless you previously built one this would explain what you are seeing. You can always build on now.
Old 05-15-2020, 12:21 PM
I'm 100% sure i did not built any Appset for Logic.
And if i did not built any LPX appset, where did the LogicProX Appset i see comes from ?
Also if Avid does not include any LPX Appset, how can it claims that LPX is supported with the S6 ?
Master module Appset blank Mishabou Avid S6 9 04-04-2020 06:43 PM
Any way to Import a Page of SoftKeys from an older AppSet? massivekerry Artist Series 3 04-01-2020 12:15 PM
Merging Appset files its2loud Avid S6 2 10-05-2018 08:11 AM
Appset dez811 Avid S1, S3, Dock and Control 5 10-07-2017 11:03 AM
Help ! Is Logic 4.5.1 & DAE 5.0 working for anyone ? Deutschland Pro Tools TDM Systems (Mac) 1 03-22-2000 03:46 AM
