What might be my system\'s limit?
Hi all,
I have a PIII 850,440bx motherboard,320 pc100 Ram,WD 6 gig 5400rpm(system), 2 WD 40gig 7200rpm(audio), Raid controller.I am planning on buying a Digi 001 and was wondering if this system will easly run 24 tracks and plug-in's.What are similar setups achieving? Thank you |
Re: What might be my system\'s limit?
This thread has most configs with results. Just find your system and enjoy the reading.
http://duc.digidesign.com/cgi-bin/ub...&f=32&t=001474 |
Ive been using the Digi001 for over a year now, using a PIII 800MHz 440bx 512MB RAM and 2 30GB quantum fireballs ATA100. This system has been 100% stable and done all what i need in terms of tracks plugins etc! I use winME and have used win98SE not much difference in the os's. I try and keep the computer just for the 001 because other hardware does tend to upset the 001! Hope this helps.
http://digi001.epizy.com |
sounds like you're on the right track. i have a p III 800 and its pretty solid. 24 tracks with plug-ins. i wouldn't mind if were a little quicker but i am pleased with the results i get presently.
Rather concerned about my system's performance | Ian Palmer | macOS | 5 | 03-13-2012 10:13 PM |
PRO TOOLS HAS ADJUSTED YOUR SYSTEM'S MEMORY: HELP! | serialcarpins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-31-2005 11:15 AM |
question on this system's specs | xian$ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-30-2005 04:49 AM |
to limit or not to limit? | Mikhail | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-09-2003 11:41 PM |
I finally found my system's limit | QuikDraw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-16-2001 06:23 PM |
