Want to Import Wav - Not Convert
I had Protools 8 and used to import WAVs created on my keyboard into it. The sound would be beautiful. When I would convert the finished song (with vocals) to MP3 however I would get these annoying clicks. It is because in the conversion process the sound can be degraded if one is not careful.
I just had that same problem again now this time with just the WAV file itself, directly importing into ProTools 9. When importing a WAV the dialog box indicates that it is "converting" the file. The file is full of pops and clicks in a new session. I thought it was due to compression and degredation. It was not. I tried importing other kinds of files such as MP3 to see what would happen. As fate would have it, I imported an Mp3 file with a blank space at the beginning. I was able to hear that the clicks were rhythmic with emphasis on the up beat, and realize that there is a click track in ProTools 9. I deleted it. No problem. I am leaving this solved post here, in case anyone else can be helped. Otherwise go ahead and have a good laugh. Last edited by Galadriel; 04-27-2012 at 06:34 AM. Reason: Problem Solved |
Re: Want to Import Wav - Not Convert
You may want to use a better converter for making your MP3 files as I have never had this happen here. But I use Wavelab for MP3 conversion(or back to wave format).
import and convert | stevegalante | Pro Tools TDM Systems (Mac) | 2 | 11-13-2008 04:39 PM |
convert+import ? 44.1>48 ? | itz | Pro Tools TDM Systems (Mac) | 1 | 03-19-2002 09:14 AM |
SD2 import and convert? | Lord Humungous | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-09-2001 10:24 AM |
Import and Convert | Xopher | Tips & Tricks | 2 | 05-13-2001 12:07 AM |
5.1 - Where's Convert and Import?? | jdh95 | Pro Tools TDM Systems (Mac) | 3 | 03-22-2001 09:46 AM |
