Old 11-17-2010, 03:31 AM
KrazieKraze KrazieKraze is offline
Default Digi 003 controls don't work and random freezes
OK, I've had the same issues for over a year now. I've jumped on various threads about issues to do with digi 003's with problems in windows 7 64, but never really got any specific help towards my issues, nor were the issues always the same. I've got a small window in which I could mess with my system without ruining the workflow of other things I do, so here's a specific thread for my issue along with a sandra report.
I see my digi 003 issues as two points:
1. Midi control - while the hard wired controllers such as the monitor and headphone volume controls work, any controllers controlling the software via midi eg: the volume faders, the transport controls... well just about every button on the 003, do no work. The faders will go up and down through automation, but you can't physically controll them yourself.
2. Random crashes. In particular when using other software such as Sony Vegas...welll to be honest even if it's just idling doing nothing with no applications open it can sometimes randomly crash. This can BSOD or can be just a freeze that will require restarting.
Now I've tried every version of Protools 8, every driver that was released. The latest attempt was when the windows 7 qualifed 8.04 was released... I even tried a complete fresh install... made no difference. Same issues I've been having ever since I bought it. As ridiculous as the idea is, I even tried taking out my wireless network card seeing that was a suggestion on DUC. No difference.
The faders and transport controls work fine on my windows xp 32 bit laptop running protools 8, so it's not an 003 hardware fault, instead it's an issue specific with windows 7 64 and/or my machine... or protools in general.
My sandra is below. Let me know if there's any other information you need. I'm really keen to fix this as it's sad having invested in the 003 only to find it's barely working properly as a soundcard let alone a control surface... combine that with the latest protools making my trusty original Mbox obsolete, and it's really not a good combo.
SiSoftware Sandra
Computer
Model : System manufacturer System Product Name
Workgroup : WORKGROUP
Host Name : StudioKrazei7
User : Studio Kraze i7
Processor
Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Speed : 2.8GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Asus P6T
BIOS : AMI 0603 05/19/2009
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 6GB DIMM DDR3
Chipset
Model : ASUS X58 I/O Hub
Front Side Bus Speed : 2x 2.41GHz (4.82GHz)
Chipset
Model : Intel Core Desktop (Bloomfield) UnCore
Channels : 3
Memory Bus Speed : 2x 536MHz (1GHz)
Memory Module(s)
Memory Module : Kingston 9905403-011A02LF 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Memory Module : Kingston 9905403-011A03LF 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : NVIDIA GeForce 9400 GT (16 SM4.0 1.4GHz, 512MB DDR2 2x400MHz, PCIe 2.00 x16)
Graphics Processor
OpenCL Processor : NVIDIA GeForce 9400 GT (16SP 2C 1.38GHz, 491.6MB 2x400MHz)
CUDA Processor : NVIDIA GeForce 9400 GT (16SP 2C 1.38GHz, 491.6MB 2x400MHz)
Compute Shader Processor : NVIDIA GeForce 9400 GT (16SP 1.4GHz, 491.6MB 2x400MHz)
Storage Devices
WDC WD3000HLFS-01G6U0 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) : 279GB (C:)
Seagate ST31000340AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (D:)
HL-DT-ST BD-RE GGW-H20L (SATA150, BD-RW, HD-DVD-R, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Vid Bckp (D:) : 932GB (NTFS) @ Seagate ST31000340AS (1TB, SATA300, 3.5", 7200rpm, NCQ)
Hard Disk (C:) : 279GB (NTFS) @ WDC WD3000HLFS-01G6U0 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache)
3.5" 1.44MB (A:) : N/A
Optical Drive (E:) : N/A @ HL-DT-ST BD-RE GGW-H20L (SATA150, BD-RW, HD-DVD-R, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS LPC Interface Controller
LPC Legacy Controller 1 : T0 A5-13
Audio Device : ASUS HD Audio Controller
Audio Codec : Realtek Semiconductor 888 High Definition Audio
Disk Controller : ASUS 4 port SATA IDE Controller
Disk Controller : ASUS 2 port SATA IDE Controller
Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : ASUS USB UHCI Controller #4
USB Controller 2 : ASUS USB UHCI Controller #5
USB Controller 3 : ASUS USB UHCI Controller #6
USB Controller 4 : ASUS USB EHCI Controller #2
USB Controller 5 : ASUS USB UHCI Controller #1
USB Controller 6 : ASUS USB UHCI Controller #2
USB Controller 7 : ASUS USB UHCI Controller #3
USB Controller 8 : ASUS USB EHCI Controller #1
FireWire/1394 Controller 1 : ASUS VT6315 Series Firewire Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Canon Inkjet PIXMA iP3000 (600x600, USB, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 4.7
i7 920
6gb RAM
300gb Raptor
1TB Sata 2
Windows 7 Pro 64bit
Digi 003
Mbox (original)
Old 11-17-2010, 04:41 AM
MikeLip MikeLip is offline
Default Re: Digi 003 controls don't work and random freezes
1. Midi control
I had this recently on Win7x64. I had multiple midi devices in Setup-Midi-Midi Studio using the same Midi-In port; and had midi-out assigned with no cable connected. I cleaned up the Midi Studio settings, rebooted, and my 002 now works again. Let me know if this helps you, or I just lucked out.
I would expect Pro Tools to crash with other software running. Thats why its called a Workstation and not an Application. I have a seperate system drive to run Adobe Premiere.
In respect to it crashing when just idle, have you done the Windows optimizations? The few times I run Pro Tools with other stuff running (Windows services, antivirus, network, etc) I expect Pro Tools to crash and am happily suprised when it doesn't (sometimes). I use Black Viper optimizations as well.
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells
Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized.
Google the DUC
Search Avid
Old 11-17-2010, 04:53 AM
I have nothing in midi studio so it isn't that
i7 920
6gb RAM
300gb Raptor
1TB Sata 2
Windows 7 Pro 64bit
Digi 003
Mbox (original)
Old 11-17-2010, 04:58 AM
What driver version you running (in Device Manager)? I had big problems getting drivers to stick (actually I think it may have been the uninstall of the old driver) until I ran Windows in optimized mode; then uninstalled; and re-ran all setups. I rebooted at every opportunity between the different setup's.
Mike.
Google the DUC
Search Avid
Old 11-17-2010, 04:55 PM
Here's my firmware (which I had to get while using the xp machine because the utility and eq buttons don't work on win7) and driver and protools versions.
003 Firmware
Boot 56A8 System 4FA8 Fader Hardware
b7.3.0.116 v8.0.0.314 v8.0.0.314 00.32
Windows 7 Pro x64
Protools 8.0.4.240
Driver 8.0.4.351
Windows XP x32
Protools 8.0.0.314
Driver 8.0.0.314
i7 920
6gb RAM
300gb Raptor
1TB Sata 2
Windows 7 Pro 64bit
Digi 003
Mbox (original)
Old 11-17-2010, 06:45 PM
My x64 002 driver is: 8.0.4.354.
Not sure if that indicates anything in respect to your 003. Can you download the seperate driver install that was released with PT9?
Maybe best to wait for a 003 user to reply with their drv ver.
Mike.
Google the DUC
Search Avid
Old 12-18-2010, 07:31 PM
MENACE3 MENACE3 is offline
i have the same problem with my digi003 in win 7 64bit
and i buy pro tools 9 thinking thats gonna solved the problem and didnt do anything
still freeeze ect. the samething if anyone know how to solved this issue please write back thanks
Old 12-19-2010, 01:04 AM
Emcha_audio's Avatar
Sounds a bit obvious, but are you sure you are using 64 bits drivers? You can't install 32 bits drivers on a 64 bits OS. They will either not work, or will make your system unstable.
Old 12-19-2010, 01:46 PM
rickthestick rickthestick is offline
There are a lot of us with a $2000 dongle. Open a ticket with Avid. The more they hear about it, hopefully, the faster they will get it fixed.
Random reboots and freezes! Tritono9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-25-2010 03:38 PM
Random Screen Freezes themidiroom Pro Tools TDM Systems (Mac) 2 05-21-2007 10:57 AM
OT: intel random freezes? (non-PT?) jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-20-2007 09:11 PM
Random freezes in Panther stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-05-2003 06:37 AM
Apparently random freezes, anyone? yin7yang64 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-21-2001 09:36 PM
