Old 05-27-2008, 12:17 AM
g00db33r g00db33r is offline
Default PT hangs on DAE Loaded
Hi all,
I'm running digi001 with LE 6.4. When opening PT it loads to where it says "DAE Loaded" then hangs there forever. I looked in the answerbase and noticed the exact error but the solution applied to maudio. I recently moved to a new place and everything with my machine is set up exactly as it was before with the exception of an external hard drive that I haven't connected yet. Could the lack of that drive have something to do with PT hanging? You guys ever had this prob before or have a possible solution. Of course I could just try pluggin that drive in... but I just moved and it's boxed up!
Possibly PT is looking for the Digidesign Databases directory and not finding it??? dunno but thanks in advance for your help
John
Old 05-27-2008, 12:19 AM
Default Re: PT hangs on DAE Loaded
P.S. PT has been working fine for a long time up until now.
Old 05-27-2008, 01:53 AM
mykhal c's Avatar
mykhal c mykhal c is offline
Hi all,
John
delete the 'DAE Prefs' folder in C:\Program Files\Common Files\Digidesign\DAE folder before starting PTLE. it will recreate itself when you restart PTLE. should resolve your problem
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 05-27-2008, 10:05 AM
I deleted C:\Program Files\Common Files\Digidesign\DAE\DAE Prefs
Still same problem.
Old 05-27-2008, 10:11 AM
Still same problem.
Old 05-27-2008, 06:14 PM
mykhal c's Avatar
we need more info. is this a new install??? an old install with a new problem?? pls post your SANDRA report. info is the key
Old 05-28-2008, 08:26 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
TRY A NEW CABLE FROM THE RACK TO THE COMPUTER...(firewire)
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 05-28-2008, 08:54 AM
JMS40 JMS40 is offline
The 001 is not a Firewire device...
g00db33r-
Yes, a Sandra report would be helpful.
Any new installations (plug-ins or software) since you last ran PT successfully?
Old 05-28-2008, 09:02 AM
[QUOTE]
OHHH...WELL I JUST SAVED A BUNCH OF MONEY ON MY CAR INSURANCE BY SWITCHIN TO GEICO ....
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 05-28-2008, 12:36 PM
DAE Loaded hangs dmichael Windows 0 07-13-2011 10:54 AM
PT Hangs at DAE Loaded message abt Pro Tools HDX & HD Native Systems (Win) 26 04-25-2011 06:32 AM
New Dell Laptop hangs on "DAE Loaded" PT8 Vista Neil Miller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-16-2009 03:30 PM
PTLE7.4CS4 w/ 002 rack hangs on DAE Loaded in Vista Scottbanger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-18-2008 10:04 AM
PT hangs on startup at DAE loaded justmull1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-20-2007 06:48 PM
