Old 09-20-2007, 07:33 PM
justmull1 justmull1 is offline
Default PT hangs on startup at DAE loaded
When I try and run protools it loads till the part where it says "DAE loaded" and then hangs.
I have completed all the steps on the General Troubleshooting thread, run the Tech Support Utility and also uninstalled and re-installed ProTools
I'm running an Mbox2 on WinXPSP2 with PTLE 7.1cs10
Sandra Report
Pro Tools Version List
Old 09-20-2007, 07:48 PM
Default Re: PT hangs on startup at DAE loaded
It's OK now - was a power issue. I unplugged the xbox controller I had plugged in and now it works.
DAE Loaded hangs dmichael Windows 0 07-13-2011 11:54 AM
PT Hangs at DAE Loaded message abt Pro Tools HDX & HD Native Systems (Win) 26 04-25-2011 07:32 AM
PTLE7.4CS4 w/ 002 rack hangs on DAE Loaded in Vista Scottbanger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-18-2008 11:04 AM
PT hangs on DAE Loaded g00db33r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 05-29-2008 01:52 AM
DAE Loaded Crash on PT startup smilez03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-19-2005 07:45 PM
