Old 11-15-2014, 02:17 AM
JimmyM's Avatar
JimmyM JimmyM is offline
Default Help needed,Heat latency Pre-Post?
Hi I have a bit of strange thing goin on with Heat.
I have a large session about 40 audio tracks around 80 minutes.
Now i use heat on all the tracks in pre mode.
Normally I did with heat is post but wanted to change an d experiment which sounds better for the tracks. Some post some pre. Any tips would be very welcome about Pre n Post, on which instruments.
But does the post mode gives more latency??
Cause protools gives an error with cpu to low.
And I'm just using some fab filter plug on toms and hats. And that's pretty much it
I was just was busy with the drums...
Or is my drive to slow??
Or should I cut the sessions in each individual song and then work in different sessions?
Any tips and suggestions are much appreciated.
My setup is;
Mbp retina i7 4 core 16gb 2.3ghz
Magma T3 expansion HDX
Hd i/o
Protools 11xx
Usb 3 drive 1tb 16mb cache max5 gb
Jimmy Makhaisingh
Producer Mix/Mastering Engineer
JimJam Studio
iMac (Retina 5K, 27-inch, Late 2015)
PT11HD
HDX /HD i/o
Magma Thunderbolt 2.0 Chasis 3T
Manley Vari-Mu / MPassive Mastering version
Sonnox bundle / McDsp / FabFilter /
Old 11-15-2014, 03:33 AM
JFreak JFreak is online now
Default Re: Help needed,Heat latency Pre-Post?
Your single session drive is most probably too slow for 80 tracks. Avid recommends no more than 32 tracks per (7200rpm spinner) drive. My experience with 10000rpm spinner has been 80 tracks shouldn't be a problem, but your mileage may vary. I would expect two drives would sort it out.
Old 11-16-2014, 09:26 AM
JimmyM's Avatar
Will the setup in disc cache help which is in the play back engine menu?
Jimmy Makhaisingh
JimJam Studio
PT11HD
HDX /HD i/o
Old 11-16-2014, 11:48 AM
Danny Caccavo Danny Caccavo is offline
The problem with "pre" mode with HEAT is that it is a DSP process - so any host plug-ins after that will force a round trip. This will cause more latency, depending on the hardware buffer, but will also use more voices (which may not be an issue anymore). I don't know why you're getting a CPU too slow error though.
Regarding Avid's track recommendations - 32 tracks on a 7200 drive is VERY conservative. It's based on having 32 tracks of continuous audio with heavy edit density.
If you can use disk cache and not starve Pro Tools for memory that should eliminate the drive as a potential issue, though.
Try raising your HW buffer size, if latency isn't a concern.
Heat, Pre or Post JimmyM Tips & Tricks 1 02-23-2015 03:41 PM
HEAT for post Nathan W. Post - Surround - Video 2 06-24-2011 09:21 AM
HEAT question--is it pre or post on each track? bashville Pro Tools TDM Systems (Mac) 3 01-20-2011 08:53 AM
Heat for post (nothing to do with Michael Mann) MIKEROPHONICS Post - Surround - Video 15 09-14-2010 10:24 AM
POST CONFORM HELP NEEDED! Gonzo Pro Tools TDM Systems (Mac) 0 11-23-1999 09:07 AM
