Re: AAE -9173 Issues
DeadShot If it's too loud, you're too old http://hphotos-snc3.fbcdn.net/hs293....5_738343_n.jpg |
Sorry you are having such awful problems and I am glad you are working with AVID tech support. I see the 12 core MP but I don;t see which AVID interface/set up you are using. Is this all with HD Native PCIe?
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
I use the new avid HD I/O analog 16x16 native with respective card. Everything in the box, connected to the box and software in the box is current/new/avid product. There is very little space for error and have been told by both techs it's the cleanest and most efficient / clean ststem they've come across.
Deadshot, At this point I would consider sticking another hard drive in your computer, installing a fresh system on it and install JUST Pro Tools. If your are still plagued by errors, you pretty definitively have a hardware issue. If you don't have the error on that drive you can start rebuilding your system there and monitor if/when the problem comes back to find the culprit.
Tim Reisig Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram) |
Ok so after a week of being in the phone with senior techs at avid we finally were able to identify the issue(s) causing the crashing and freezing. Guess what, it's NOT hardware!
If you ran pt10 and upgraded to OS x on your Mac, they do not play well together. Pt10 needs to be removed in every way. This can cause all kinds of issues. this seemed to be the real fix, I had some residuals left over and not sure why they didn't get removed. Also just placing them in your trash does not kill them, you need to empty them out. The freezing was caused by odd audio conversions into pt11 from 10. The sessions started in 10 and never had issues but once brought into 11 they formed some odd audio traits. If I zoomed in I would see maybe 3milleseconds of Audio highlighted in red, not sure why but removing it, eliminated the issue. Not sure if it had been a crossfade or just a glitch in the matrix. I want to thank Brandon, Matt and Eric at avid for really digging deep into this, as I said this was a week long head scratcher with a lot of frustration behind it. These guys stepped up and figured out. I think we spent close to 15-20 hours on the phone combined to figure this out. Hopefully the information above will help some people out. Not to say that the people's suggestions on the forums aren't helpful but going to the source is the best option, even if you have to pay the money. Unfortunately many on here really don't know what they are talking about and will have you chasing your tail if you start listening to wild goose chases they put you on. Much like signal flow, start with the source then work your way out. Thanks again avid!!!
Deadshot, I am having the same issues. The odd audio traits you talk about… do they show like spikes in the waveform that have absolutely no reason for being there? When I remove them, PT11 behaves in a more normal way but while they are there, I've got bursts of noise, CPU spikes and odd plugin behaviour.
Anyhow, so the cure is to completely uninstall PT10, right ?
http://www.ogregomixmaster.net ______________________ Mac Pro (Late 2013) 3.5 GHz 6-Core Intel Xeon E5 16 GB 1866 MHz DDR3 ECC AMD FirePro D500 3072 MB OS X 10.10.5 PT12.2 Connected Interface : Lynx Hilo (Thunderbolt) USB3 ports used : All (3 Hard Disks, Wireless Keyboard & Mouse, Ilok2, Webcam) HDMI : Monitor connection |
I ws having the -9173 problem with sessions transferred from PT 10 to 11,, I placed the sessions on a SSD and ran them and got around it that way.. Not ideal,, as I can't use a non SSD on a real time bounce out using inserts, , but at least that is a quick easy way.
Same issue here...all plugins taken down, strictly audio then 30 seconds into a bounce and AAE-9173 rears its ugly head. I'm going to try the app that kills PT preferences and anything else I can find on here, if I get lucky I'll keep you all posted. Thanks for your help...I feel a little better already (just a little); apparently misery really does love company
AAE 9173 Pro Tools ran out of CPU power | Kinh | Pro Tools 11 | 223 | 12-10-2017 09:39 AM |
Pro Tools 11.1.0 AAE-9173 Error | justus1900 | Pro Tools 11 | 4 | 12-22-2015 02:46 PM |
11.2.1 My Findings, -9173 error with BTD | Intransit | Pro Tools 11 | 77 | 11-23-2014 04:12 PM |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-29-2014 11:56 PM |
Aae-9173 | txrx | Pro Tools 11 | 5 | 12-28-2013 04:34 PM |
