Old 05-18-2007, 05:26 AM
linchpinc linchpinc is offline
Default Motu 8pre to 002 via ADAT?? Help!
I have purchased a Motu 8 pre recently to add inputs to my LE steup with which I currently use a 002. I am having problems getting the inputs to show up in the i/o section in the mix window and getting signal into pro tools can anyone help me here?
Old 05-18-2007, 07:24 AM
tomdiek tomdiek is offline
Default Re: Motu 8pre to 002 via ADAT?? Help!
To use the ADAT optical inputs you will do this:
Go to the setup menu and select hardware. Select ADAT. Make sure the sample rate on the MOTU matches the session sample rate.
Then go back to setup and select I/O. Select the inputs tab. You'll see analog 1-8, optical 9-16 and S/PDIF 17-18. Creat 8 new paths and match the path with the inputs. ie path 1 to input 9, path 2 to input 10 etc.....
Once this is routed you then go to the inputs on your track and select interface and you'll see the paths 1 through 8. Apply them to whichever track you wish to record from this source.
Hope that helps!
Pro Tools 2018.12
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
24 GB 1867 MHz DDR3
Apogee Symphony MKII Thunderbolt 2X6
Old 05-18-2007, 07:28 AM
Yes I am sorry don't know much about using them so I just need to find out the right way of hooking it up?
Old 05-18-2007, 07:35 AM
This is probably a stupid question but you need two optical leads don't you?
My bad..I saw that you had the ADAT in your subject after I posted.........check the post before this for the setup.
Pro Tools 2018.12
4 GHz Intel Core i7
24 GB 1867 MHz DDR3
Old 05-18-2007, 07:38 AM
Actually you just need one optical cable. Optical out of the MOTU to the optical in of the 002. Keep in mind You will be limmited to 48kHz though.
Pro Tools 2018.12
4 GHz Intel Core i7
24 GB 1867 MHz DDR3
Old 05-18-2007, 07:40 AM
I have tried that and for some reason there is no signal on my meters in pro tools
Old 05-18-2007, 07:48 AM
Do I need to have the 002 set up for mic inputs?
Ok....If things are routed properly then It could be several other things. What are the details of your setup? What are you recording from? Mics, line inputs? What is your source? Are you getting signal on the preamp?
It's possible that it could ba a bad cable as well.
Pro Tools 2018.12
4 GHz Intel Core i7
24 GB 1867 MHz DDR3
Old 05-18-2007, 07:56 AM
If you're using the ADAT optical you will use the paths that you set up in the inputs section of setup.
Pro Tools 2018.12
4 GHz Intel Core i7
24 GB 1867 MHz DDR3
MOTU 8pre Dvargas Pro Tools 9 9 03-15-2012 01:16 PM
MOTU 8PRE via Optical alpethtel@yahoo.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-28-2009 04:17 PM
Using MOTU 8pre with 002 hutchypie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-10-2008 06:28 PM
DIGIRACK 002 looses connection to MOTU 8pre via ADAT conn. sekie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-12-2007 08:37 AM
Motu 8pre to 002 via ADAT?? Help! linchpinc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-18-2007 05:26 AM
