Cannot comunicate with fader packs Error
Hi there,
I'm using pro control with 3 fader packs, pro tools 6.9cs2 on a G5 2gig and every few days I get an error when I open up pro tools saying "Cannot comunicate with fader pack please power cycle unit" the problem is it's actually very difficult to switch just the pro control off in our studio. I resolve this by reseting the fader packs in peripherals but I was wondering is there anyway to resolve this issue as it has gotten progressively worse over the past few months. Thank you, Mark. |
Re: Cannot comunicate with fader packs Error
I have occasionally had the same message although i only have the one unit - no extra packs, and found that all i needed do was restart the ProTools software and it all worked fine. Powering down the PC is completely impractical for me as well.
adam taylor video editor/dubbing editor/sound design/motion graphics/compositor United Kingdom |
Thanks for your reply Adam. There has to be some reason for this and some way of preventing this from happening nearly every time I start pro tools.
Thanks, Mark. |
one thing i have noticed is that since we have had the room wiring completed a couple of weeks ago, the problem has disappeared. Everything used to be on the same power switch - so everything went on together......now the G5/ProTools Rig is out in the corridor and switched on first...then the PC/monitors are switched on in the room. Perhaps if you leave a little time between powering up the rig and the PC, then the problem may cease?
Looking for ProControl Fader Packs and Edit Pack | BassBuddha | ProControl, Control|24, Command|8 | 6 | 01-31-2011 01:47 PM |
ProControl and Fader Packs suddenly offline | Atardecer | ProControl, Control|24, Command|8 | 4 | 10-15-2008 11:09 AM |
Fader Packs? | funkdefino | ProControl, Control|24, Command|8 | 7 | 05-12-2004 08:45 PM |
Connecting multiple Fader Packs to the Pro Control | 2 Cold Recording | ProControl, Control|24, Command|8 | 2 | 07-31-2002 02:16 PM |
Extra Fader Packs | nozza1 | ProControl, Control|24, Command|8 | 4 | 07-20-2001 11:21 PM |
