Mbox issues - perpetual LE 5.2 crashes
Just set up a small rig at my home:
Ti G4 667/1GB ram/PT LE 5.2 PT Mbox/LE 5.2/80GB Glyph companion drive MOTU Fastlane USB 2x2 midi interface Kensington USB turbo mouse Dr. Bott 3 port USB hub I have been getting random errors Type 1, 2 and 3 forcing PT to quit. I have shuffled the USB devices around in various combinations thinking it might be USB related to no avail. Anyone else experience this problem with a similar configuration? Digi, any thoughts? |
Re: Mbox issues - perpetual LE 5.2 crashes
try using a the stock apple mouse for a while...usb mouses can cause issues in my experience.
Pro Tools & Logic Programmer, Engineer, Consulting, Education |
Thanks Marc. Will give it a shot.
>"PT Mbox/LE 5.2/80GB Glyph companion drive"
Hi John, looks like a really sweet setup, except for the mouse [img]images/icons/wink.gif[/img] Do you have access to a Pro Mouse? If so, give it a go... Also, try a different usb port on the 667. How's the companion drive? Does it have the same body of the mbox?
A Blues Harp and PowerBook is all I need ... along with Analog Signature Pack & BlueTubes 3.0 !! |
I'm going to give the Pro Mouse a shot tonight.
The companion drive is cool. Nearly identical body and color - a bit bigger length wise than the mbox. They nest together nicely side by side. |
Whats the companion drive all about.
Is it a USB hard drive. If so, is it fast enough for use with audio or do you use for storage only? Is it a Digidesign bit of gear? I hope to hear from you soon Mark |
Mark:
I don't own one, but was looking at them too so can answer your questions [img]images/icons/tongue.gif[/img] It's a Firewire drive, it's definitely fast enough to use for audio, it comes in 3 sizes (40/80/120 gigs), it's made by Glyph.......and you can check it out here Looks pretty cool to me, although a bit pricey for what it is. Then again, Glyph are known for amazing customer support - so it might be worth the extra dosh. Still haven't decided what I'm gonna do yet........ [img]images/icons/rolleyes.gif[/img] Steve. |
just a word about 1 to 3 error type on Mac. As I observed (Gestalt etc.) it appears in memory overflows and/or continued memory dumpings. In clearer words : simply an app that ran out of its memory in RAM. So I doubt it could be mouse-related only.
See if PTLE is ok without killing the mouse [img]images/icons/wink.gif[/img] , if not see if your clipboard (often causing 1 to 3 r-type since OS 9) is not filled by a gigantic amount of sound or even an odd stored matter (e.g. RTF, QuickTime multilayered cut, or even HTML). Try working with an empty clipboard. You can almost empty it by selecting a "standard" Finder object like a file name.
Fear Truth as it may become real someday. |
One of the best features is its size - small enough to bring between home and studio.
Thanks Yelhahc and others.
I am interested in a backup drive for Mbox on an old iMac. I understand that USB drives transfer data at around 700kb per second. I calculate that this would be too slow (is around 130 kbps [mono] a good rule of thumb for 24bit 44.1?). Thats around 5 or 6 mono tracks. If so, a USB (and the old iMacs only have USB) hard drive would only be for storage of audio. Any ideas appreciated? Brands? Speeds? Seeya mark |
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) | Lucky Bastard | Getting Started | 6 | 01-16-2014 03:29 PM |
Mc Transport Install/EUCon crashes [fixed] & other issues | Xill | Artist Series | 12 | 07-26-2011 03:56 PM |
The Ultimate trouble shooting guide. Fixing crashes, freezes and performance issues. | Kunga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-06-2010 08:08 AM |
Crashes & Printing Issues w/ PT 8.0.3, Waves 7.0.1 on SL | acacia | Pro Tools TDM Systems (Mac) | 6 | 01-13-2010 11:09 AM |
*Pro Tools 7.1 , G5, HD3 crashes and issues | swayne | Pro Tools TDM Systems (Mac) | 1 | 04-26-2006 05:21 AM |
