A problem w/ looping a region. Is it an ie. option in PT2018 that I have missed?
Hi!
i have an issue w/ PT2018.7. I'll try to explain. When I choose section in a track that I want to listen as a loop. When I choose the part that I want to listen - PT2018 let me "color" that part, BUT when I press stop the part in the track disappears. And I have to chose that part again. Appart that PT2018 runs great. Is it an ie. option that I have chosen that I don't understand? What should I do to keep the region in a track, so I can loop it again and again. Thank You for your reply!
Win11 Pro Intel i7-12700K @3,6GHz, RAM 32GB UAD Apollo and pre-amps, Pro Tools 2023 lots of plugins |
Re: A problem w/ looping a region. Is it an ie. option in PT2018 that I have missed?
Hi
Disable under Options "Insertion follows Playback" Then the selection stays after stopping playback... greetings |
TrackerLe,
Thank You. Now it works again like charm! Every day I learn something new. Greetings!
When Keyboard Focus is on in the Edit Window, the "N" key toggles this on and off. I spent countless hours trying to figure out why this kept happening when the feature was introduced. It's pretty easy to bump the "N" key when hitting the spacebar.
Scott Gatteño |
The keyboard toggle N was introduced before Pro Tools 8 or 9. Maybe back to 5 or 6 (memory is hazy going back that far.) This isn't close to relatively new (though it is something to be aware of.)
Also you can see the indicator below the tools as one of the buttons (that you can also click to turn it on/off)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Good point on the toolbar icon. In the attached pic, it is turned off. It would be blue if it was on.
Scott Gatteño |
How does region looping preserve the original length? | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-30-2009 11:04 PM |
EA Warping and Region Looping | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-08-2008 11:06 AM |
Looping regions without listening to whole region? | creativesounds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-15-2007 02:38 PM |
Newbie - Looping a region in PTF | Nicholas Turner | Digidesign Hardware & Software | 4 | 03-07-2003 04:28 PM |
Missed option in PT5.01 | smcoptyltd | Tips & Tricks | 2 | 12-13-2000 03:31 PM |
