Old 12-02-2007, 08:51 AM
Ford Prefect Ford Prefect is offline
Default Help: BF Essentials
What are the Correlation Meter, Noise Meter and the Meter Bridge good for? What tell me the displays of these BF Essential Plug-ins?
For example: I use the FXpansion BFD Drum Modul. A single kick drum hit makes the needle of the correlation meter pop over +1.0. A slight single hi-hat hit goes up to +0.4, a hard hi-hat hit goes up to +1.0. During playback of the whole song with guitares and bass and all the stuff the needle stays at over +1.0 and does not move. What does that tell me?
What shows me the Noise Meter and how do the filters work?
And my last question: What means "RMS" and "peak" on the noise meter and meter bridge panel?
Thanks for your help.
So long and thanks for all the fish!
Old 12-03-2007, 04:53 AM
ejwells's Avatar
ejwells ejwells is offline
Default Re: Help: BF Essentials
The free Bomb factory plugs (aside from the very useful compressor) are free with good reason.
The tuner can be somewhat useful, but it's a pretty slow responder. Just forget you have all that other junk.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 12-03-2007, 11:02 PM
Stiff Stiff is offline
I actually used the Funk Logic Masterizer (is that what it's called?) in a track for a client a couple of weeks ago
Daily news & reviews
www.ProToolerBlog.com
Old 12-04-2007, 01:22 AM
ejwells's Avatar
Funk Logic is a hoot. A lot of folks don't know that it was developed as a joke, but I too have used it on some stuff.
Old 12-04-2007, 04:04 PM
ondruspat ondruspat is offline
I've used the meter bridge for matching volumes of songs when I preparing a compilation to burn. It's very easy with the visual feedback from the plug.
"Sometimes having limits keeps you sane"- Albee1952
Old 12-06-2007, 09:54 AM
French links French links is offline
The correlator meter is useful to check some phase shift issues.At minus 1 or circa seems there is some phase cancellation that can occur.Useful if your ears are rubbish cause it's easily noticable.
For a full mix the needle should dance between 0 and +1.
The Phasescope works better and is loads more sensitive.
I've never use the others appart from the tuner.
That's all I know about that.
Old 12-06-2007, 10:01 AM
sunburst79 sunburst79 is offline
Any device with a ON/More-On switch is good in my book
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 12-06-2007, 10:15 AM
Funklogic only helped me to created the creative radio or vinyl sound for an intro or outro.
Unless your mix is too clean (who would complain about that?) your can use it to avoid the sudden drop between two tracks (digital silence black out!).Thus between two tracks you can insert that noise very gently allowing the mastering function: Audio during pause.It gives good results, it emulate a kind of room ambience, even if it's better to get a real one.Then your album will sound as if it had been recorded in one go.Do I make sense?
Old 02-04-2010, 11:20 AM
Tank Tank is offline
I would like they were also in tdm format, expecialy the meter bridge.
Old 02-04-2010, 03:28 PM
Gotta love it when threads like this pop up from the archives!!
Pre-Roll and Essentials sighermike Pro Tools M-Powered (Win) 0 11-19-2010 10:58 PM
PT Essentials will not run. gilttag Pro Tools SE and Essential (Win) 1 04-26-2010 01:16 PM
PT Essentials Upgrade Gabriel7 Pro Tools SE and Essential (Win) 1 12-29-2009 07:00 AM
001 + BF Essentials 3.70 - please help =] randerson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-13-2008 01:40 PM
Anybody Using BF Essentials? M2E Pro Tools TDM Systems (Mac) 2 12-29-2002 02:43 PM
