Old 01-25-2011, 02:21 AM
Caravestara Caravestara is offline
Angry Yellow Xpand! panic on Mcbkpro leopard
Hi and first of all, Sorry for bad english writing
I worked on a session using Midi sequences with Xpand!, on an iMac24 (Tiger) PTLE7.4.2
Now I try to complete my work on the same session but on the macbookpro (Leopard 10.5.8)PTLE7.4.2, Xpand! gets Yellow, panics and Protools quits systématicaly
I am at the end of the world and need to complete this session quickly. How to manage with Xpand! ? How or where to get an working version of Xpand!?
Thanks you all
Old 01-25-2011, 03:01 AM
Richard901 Richard901 is offline
Default Re: Yellow Xpand! panic on Mcbkpro leopard
I think you need Xpand! version 1.0.3.
http://avid.custkb.com/avid/app/self...3=1450&Hilite=
Click on View available downloads.
Xpand! 1.0.3 Updater (Mac OS X Leopard) for Pro Tools 7.4.2
You will need to login to download.
Richard
High Sierra 10.13.6
Pro Tools 2019.6.0
Old 01-25-2011, 05:53 AM
Smile Yellow dead, but: Xpand! : dat file not found
Very well, it works now, Thank you Richard for your excellent suggestion,
I now get this message in the Xpand! section :
"Xpand! : dat file not found"
I've been stupid, Yesturday I tryed to re-locate Xpand! datas thinking it would help.
Should I re-locate data's ? Where are these data usualy located ? Is it ih the ''AIR'' folder in Aplication support / Digidisign ?
Old 01-25-2011, 07:05 AM
I'm running PT 9, so I don't have this .dat file, but I've searched and found this:
The Xpand! Plug-In is installed to this location:
Hard Drive/Library/Application Support/Digidesign/Plug-Ins
And that the Xpand! .dat file is located here:
Hard Drive/Library/Application Support/Digidesign/Xpand!
Richard
High Sierra 10.13.6
Pro Tools 2019.6.0
Old 01-25-2011, 07:22 AM
Thanks Richard, I realy apreciate
I might have a problem because I went thru your advices and did'nt find any dat file,
Maybe should I download it!
Does the Xpand! use samples or does it use synthesis ? I though it used synthesis.
Old 01-25-2011, 08:30 AM
Unfortunately, the .dat file is not available for download.
Here's some ideas:
1. As you are using Leopard on the MacBook Pro, you should be able to use Time Machine to restore the .dat file to its original location. - Sorry, I should have thought of this before.
2. Get the .dat file from the iMac.
3. Get the .dat file from the Pro Tools installation CD.
Richard
High Sierra 10.13.6
Pro Tools 2019.6.0
Xpand Yellow Screen A-RON Virtual Instruments 5 10-29-2011 08:24 PM
Xpand is all yellow??? and i had to take some plug ins out. Why??? TheArch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-06-2009 04:01 AM
Xpand! Loading up Yellow!! evolmonster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-17-2008 04:03 PM
Xpand! is all yellow Delso Virtual Instruments 2 05-06-2008 06:13 AM
Xpand! GUI all YELLOW, can't read...??? bpinco3 Pro Tools M-Powered (Mac) 2 01-30-2008 08:12 PM
