I Need Help With Lightpipe
I getting ready to buy a Digidesign Digi 002 Rack, and I'm to going to buy a Behringer board to run through the 002 with the Lightpipe. Here's my question, what Behringer board would be best to buy since I need at least 16 tracks to run simultaneously? Or is there any other boards that would work with the Lightpipe you would suggest?
Thanks for your help y'all |
Re: I Need Help With Lightpipe
The only boards with lightpipe are digital boards and the only Behringer digital board I know of is several years old. Are you referring to the Behringer ADA8000? That is not a board but does work with the 002 as it has 8 mic preamps and a lightpipe output and will expand the 002 inputs to 12 on a budget. To get to 16 mic inputs, you will still need 4 more preamps with analog outputs and patch them into the 4 002 line inputs(5 thru 8) and you should set the input level switches on the back to the +4 position(because most outboard preamps have +4 line level outputs).
lightpipe help please help!!! | feinded | Pro Tools M-Powered (Mac) | 4 | 05-22-2007 09:35 AM |
96 i/o with Lightpipe | proxy | Pro Tools TDM Systems (Mac) | 7 | 06-27-2006 07:53 AM |
Lightpipe VS AES/EBU | ryan de topanga | Pro Tools TDM Systems (Mac) | 3 | 12-03-2002 10:41 AM |
More Lightpipe! | Record-n-Play | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-17-2002 05:59 AM |
Lightpipe . | Rob K. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-28-2002 04:38 PM |
