#21
Re: Midi Input Port 'None'
Ok. I've done the following trouble shooting steps.
1. Prior to install, I made sure my system was optimized per instructions on digidesigns. No problem. It records fine, just no midi. 2. Reinstall. I installed PT7.x from the disc received with the new OO3 rack fact +. Installed PT8. Found not apparently midi capable. Uninstall. Reinstall 7.x from disc to check if working under that version. Again no midi ports listed in Midi setup. Reinstall PT8. 3. Perform disc install then upgrade from downloaded file onto family quad core desktop. No optimization steps. Just an install to see if midi ports available and not a problem on more than one system. OO3 rack with ports selectable in Midi Setup. Obviously, something intrinsic to laptop itself, not install program or upgrade. 4. Thought 4 pin firewire port may have some issue as alluded to with certain Macs on digidesigns website and got a ExpressCard Firewire Card with 6 pin connector. Model was recommended on Digidesign site. Still no midiports in midi setup, but PT8 works flawlessly otherwise. 5. Internet search for answers. Join Digi User Conference. 6. Attend to DAE files and preferences. Although I didn't expect these to be a problem, I did delete them per the post regarding troubleshooting. 7. I did not reinstall Pace drivers. Thought this unlikely factor. 8. Downloaded Tech Support Utility, running Sandra to respond. 9. Contemplating entering a service agreement with unholy minions and promising first born, but that seems a drastic step to take at the moment. Think? I'll post Sandra results in follow up thread. |
#22
SiSoftware Sandra
Processor Model : Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz Speed : 2.00GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing System System : TOSHIBA Satellite A305 Platform Compliance : Intel Centrino Duo Mobile Technology Mainboard : Intel Corp. Base Board Product Name Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : INSYDE 1.50 Total Memory : 2.88GB SO-DIMM Chipset Model : Toshiba GM45 Mobile Controller Hub Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 3GB SO-DIMM Shared Memory : 128MB Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Hyundai HYMP125S64CP8-S6 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5.0-6-6-18 3-24-6-3) Memory Module : Hyundai HYMP112S64CP6-S6 1GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5.0-6-6-18 4-24-6-3) Video System Adapter : Mobile Intel(R) 4 Series Express Chipset Family (128MB DDR3, 533MHz, PCI, SM4.0) Storage Devices WDC WD2500BEVS-26UST 250GB (SATA150, 2.5", 5400rpm, NCQ, 8MB Cache) : 233GB (C:) Seagate FreeAgent XT 2TB (SATA300) : 1TB (G:) Hitachi HDT725025VLAT80 250GB (USB, 3.5", 7200rpm, 8MB Cache) : 233GB (F:) WD 2500JS External 250GB (USB) : 233GB (E:) TSSTcorpCDDVDW TS-L633P (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 279MB (D:) Logical Storage Devices TOSHIBA SYSTEM VOLUME : 1GB (NTFS) SQ004829V03 (C:) : 231GB (NTFS) @ WDC WD2500BEVS-26UST 250GB (SATA150, 2.5", 5400rpm, NCQ, 8MB Cache) MusicMain (G:) : 1TB (NTFS) @ Seagate FreeAgent XT 2TB (SATA300) Improv Tool Kit (D:) : 279MB (CDFS) @ TSSTcorpCDDVDW TS-L633P (SATA150, DVD+-RW, CD-RW, 2MB Cache) Music (F:) : 233GB (NTFS) @ Hitachi HDT725025VLAT80 250GB (USB, 3.5", 7200rpm, 8MB Cache) My Book (E:) : 233GB (FAT32) @ WD 2500JS External 250GB (USB) Peripherals LPC Hub Controller 1 : Toshiba ICH9M LPC Interface Controller Audio Device : Toshiba (ICH9) HD Audio Controller Audio Codec : Realtek Semiconductor 0268h Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) HDA softmodem Serial Port(s) : 1 Disk Controller : Toshiba (ICH9) Mobile SATA AHCI Controller USB Controller 1 : Toshiba (ICH9) USB Universal Host Controller USB Controller 2 : Toshiba (ICH9) USB Universal Host Controller USB Controller 3 : Toshiba (ICH9) USB2 Enhanced Host Controller USB Controller 4 : Toshiba (ICH9) USB Universal Host Controller USB Controller 5 : Toshiba (ICH9) USB Universal Host Controller USB Controller 6 : Toshiba (ICH9) USB Universal Host Controller USB Controller 7 : Toshiba (ICH9) USB Universal Host Controller USB Controller 8 : Toshiba (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Toshiba R5C832 IEEE-1394 Controller FireWire/1394 Controller 2 : Lucent/Agere Systems (Was: AT&T MicroElectronics) FW643 PCI Express1394b Controller (PHY/Link) System SMBus Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Adobe PDF Converter (4000x4000, Colour) Network Services Network Adapter : Realtek RTL8102E Family PCI-E Fast Ethernet NIC (NDIS 6.0) Wireless Adapter 1 : Intel(R) Wireless WiFi Link 5100 (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System(s) Windows System : Microsoft Windows Vista Home 6.00.6001 (Service Pack 1) Platform Compliance : x86 Windows Experience Index Current System : 3.8 |
#23
Also, in the System Configuration Utility, is the MMERefresh service running (checked) in the Startup Items or System Services tabs? |
#24
When I use the computer and the OO3 I disable any process that could potentially cause a problem, this includes the wifi. I'll disable everything not neccessary to the process. I don't expect I disabled the Ethernet card.
The MMREfresh does show up in the sys config and appear to be running/startup. I checked using the config utility. |
#25
So... I was having this problem (Vista, digi003Rack, PT8.0 from the download). I was going to look and see if there were any install options I didn't choose, so I restarted the setup utility. I chose "repair install" and let it do its thing. Now my MIDI port is available again.... I Don't know how long it will stay, but it's here for now
#26
Interesting. I'm glad that worked for you. I attempted the same thing after I installed the original disc version to see if the upgrade was the problem. No luck. I'll attempt again, but sounds kinda flaky that it would repair or install incorrectly.
#27
Ok. Practically anything not used has been disabled. MMRefresh is running. I've clean all things up.
ProTools does start slightly, but noticably, faster. But, sadly, no midi input/output noted in Midi Setup. |
#28
I think it may be time to call tech support by phone - it sounds like you may have defective MIDI ports...
#29
I'll call. Although, when I have a midi device connected to the OO3, the 'In' light on the OO3 flickers when I have the midi device send information.
Furthermore, if the ports were bad, why would they show up and be selectable in midi setup on other computer I used to test for that very issue? It seemed to me, if the ports were bad and the issue was intrinsic to the unit, the exact same issue would afflict any system I plugged them into, not just my laptop. I'll get the desktop I used to test if the midi ports were selectable and see if the ports actually pass info via midi into ProTools on that system. Mainly as I think it's not the unit, but some interface issue with my laptop. That way I can save the trouble of sending a perfectly good unit back as opposed to hunting down the interface problem. |
#30
Hello has any one come up with an answer besides going back to pt 7.4???
I'm am new to this furum chat.. But I too just got pt 8.0 and I'm recieving the digi 002 midi imput port none I'm still old school running my akai mpc 2000 and I need the mtc to time all my sequences... and "digi 002 midi imput port none" is my problem.. I'm not able to choose any port! |
MIDI Setup - Not seeing USB Audio Device as an Input Port Option | oldtracy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-15-2013 09:22 PM |
No Midi MBox input port available? | cprescott1972 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-31-2008 12:30 PM |
M-Audio Input port activation problem | parabola | Pro Tools M-Powered (Win) | 1 | 03-01-2008 06:38 AM |
two midi input devices, one port | therecordinghouse | Tips & Tricks | 2 | 07-14-2006 07:20 PM |
MTC input disabled when "Beat clock to port.." or "MTC to Port..." is enabled | OKden | Pro Tools TDM Systems (Mac) | 2 | 10-27-2001 03:24 AM |
