  #31
Old 09-02-2009, 10:18 AM
Dizzi45Z Dizzi45Z is offline
Default Re: Huge adc bug!??
Woah! Okay. I did exactly what you explained by creating a new project, and it seems to be working fine for me right now. Delay Compensation is set to Long and HW Buffer size is 1024 Samples. I am on Pro Tools 8.0.1. I am using the RTAS version of Maxim. Delay compensation is not bypassed anywhere.
This is weird because I know I have seen what you have talked about in the past. Are others here seeing it working fine?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools 12.8.3 HDX Mac OS 10.12.6
Mac Pro Quad 3.2 Nehalem with 32 GB RAM
Noisebox Studios -Utah Recording Studio
  #32
Old 09-02-2009, 10:26 AM
Okay... Sorry for another quick post, but I just tried it again with setting my HW buffer size to 256 and it was an absolute nightmare. So it must be a bug based on your playback engine settings.
So maybe another workaround is to record midi with Delay compensation Playback buffer set to 1024.
  #33
Old 09-02-2009, 10:51 AM
woodsdenis woodsdenis is offline
Just set HW buffer to 1024 and lo and behold it works back to 256 and nightmare. Good catch Dizzi.
Cmon Digi we have even regressed this bug for you now.
Denis
Mac Pro 3.3 hexacore
24 gb RAM
Lion
PT 10 HD Native
  #34
Old 09-02-2009, 11:18 AM
studiojimi's Avatar
studiojimi studiojimi is offline
i'll bet the cats that have already left the building
are rolling their eyes daily...
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
  #35
Old 09-02-2009, 11:27 AM
masterplan masterplan is offline
Ok. But playing a software instrument with the hardware buffer size at 1024 is a complete nightmare and has nothing to do with playing music.
Thanks for finding it!
Brings us a bit closer to a solution.
Come on digi!!!!!!!!!!!!
GO GO GO GO GO GO GO GO GO GO GO!!!!!!!!!!!!!!!
  #36
Old 09-02-2009, 02:24 PM
muhis1 muhis1 is offline
I'm with you mr. Masterplan.
The 1024 samples buffer size isn't an option!
Not even 256 is playable.
/J
Mac Pro Nehalem 2,66 with 12 GB ram, Pro Tools 8.1, HD2 Accel, 192 I/O with 2 882s, UAD 2 QUAD OMNI. OSX 10.6.4
  #37
Old 09-02-2009, 02:27 PM
/J
And it scares me a little bit that you're on 7.4 with that "not playing back with ADC when rec i toggled" problem, and that the problem has evolved into a nightmare in version 8!
DIGI!!!....loo diggi...lej!!
  #38
Old 09-02-2009, 02:31 PM
DigiTechSupt's Avatar
Please give us some time this afternoon to look at this.
For future reference - if you absolutely, positively need a response it's best to use the Tech Support Request Form.
Avid Audio Tech Support
Support FAQ
  #39
Old 09-02-2009, 03:57 PM
/J
Why is it not a playable option? On my system, when I choose 1024 samples for my buffer size, when I record the instrument, the instrument feels instantaneous.
----Edit----- Never mind.... I forgot I had switched back to 256.
  #40
Old 09-02-2009, 05:24 PM
carlone carlone is offline
On my rig I'm seeing the same problem you found.
Seems like when I disable ADC on the Instrument track it works fine for playback.
That suggests that it's not "writing" the record pass with the ADC adjustment. Or writing the data earlier (based on the delay amount).
It's a bug or put another way "not the desired behavior" :)
Try disabling ADC "only" on the Instrument track and see if it works for you (as a work around till it's fixed).
New Mac Pro and HD2 HUGE PROBLEMS Dolly Pro Tools TDM Systems (Mac) 6 09-13-2010 03:12 PM
HUGE Problem with HD 8.0.4 maybe ADC??? smilerecord Pro Tools TDM Systems (Mac) 0 08-19-2010 09:35 AM
A Huge THANK-YOU RussUK Virtual Instruments 16 06-03-2009 09:00 PM
i have a huge problem!!! please help! moisesgalvan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-15-2007 05:51 PM
huge problems with 001 rhysw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-14-2004 07:51 PM
