Old 11-06-2010, 03:24 AM
dougbiggs dougbiggs is offline
Default vocals sound distorted on record but play back fine
Vocals monitor distorted while recording (esp peaks) but meter well under clipping. Same recording sounds great in playback...
(Imac 3ghz, sys 10.6, 002 -or mbox2pro-no difference, PTle 8.04, OWC firewire drive)
any thoughts?
doug
Old 11-06-2010, 07:35 AM
Ben Jenssen's Avatar
Default Re: vocals sound distorted on record but play back fine
First thought: If it sounds good, it is good.
Second thought: Something is wrong. Either with the way the way you are diagnosing the problem (a badly calibrated meter), or... I don't know.
Edit: wait, you hear distortion when recording but not when playing back? If so, you have a monitoring problem. Is the source doubling up when you are in record?
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini 2018, six core i5 3.0 gHz, 32 gb RAM.
Focusrite Scarlett 2i2 3rd gen, Dynaudio BM6's, Command 8 and iPad w/Avid Control.
Pro Tools 2020.11, Mac OS 10.15.7.
Old 11-06-2010, 06:01 PM
Nope, can't double up with my 002 config ... normal 'low latency' mode. Never had this with 7.4 and have only been using 8.04 for a short while, noticed this in the last few days. Up-to-date digi and waves plugs + celemony
Old 11-06-2010, 09:23 PM
albee1952 albee1952 is online now
Trashing prefs is always worth a try for ANY odd behavior
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 11-06-2010, 10:32 PM
Rob0214 Rob0214 is offline
Your plugs are disabled in low latency mode. Are you sure they aren't dropping the gain on playback? Are you using pre-fader metering?
Also, you might want to check under preferences: Link Record and Play faders.
open, record and play back on NAS arturoquispe Pro Tools 10 1 12-17-2011 01:55 AM
ProTools 8 M Powered won't play back after record Leeber Pro Tools M-Powered (Win) 0 07-29-2011 04:53 PM
cannot record or play back haroldmarkjordan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-14-2010 09:27 PM
can't record or play back cpu usage at 99% but set to 85% HELP wylde8185 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-04-2007 07:25 AM
distorted sound while playing back ceyda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-15-2006 09:30 PM
