D-Control Grouping Question
Attempting to use the soft keys window to show groups. I've selected GROUP under the Soft Keys Management buttons, pressed GROUPS in Custom Faders, but an unable to display the groups in the Soft Key window. (As per the D-Control Grouping Basics PDF: To recall a group simply press the Groups button from the Custom Fader Controls then press the Soft Key for the group you want to access.)
What am I doing incorrectly? |
Re: D-Control Grouping Question
Of course, I forgot to enable BANK SEL under Soft Keys Select/Midi. I'm leaving this post in case anyone else has an elderly moment
yes ... was about to suggest that :
That same bank select switch has multiple access functionality depending which CF mode your in : Custom ..... Bank select pages display custom groups Groups ..... Bank select pages display Mix / Edit / All groups Masters .... Bank select pages display track types Plugins .... Bank select pages display pages for plugin parameters in CF mode Chris
Chris Lambrechts Applications Specialist- Live Sound |
Thanks Chris. I should mention that the current downloadable D-Control guide pdf has quite a few references to controls and buttons that have been relabeled (i.e. MASTERS in Custom Faders vs. TRACKS). I presume that the updated guide for Pro Tools 8 will reflect the proper labeling.
plug in question. Grouping and docking.. | timos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-11-2011 01:28 PM |
Grouping problems! All group won't work, grouping channels together spontaneously | farmfresh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-18-2009 09:57 AM |
Grouping Question | woodywho | Tips & Tricks | 5 | 08-08-2004 02:05 AM |
Quick grouping question... | Micah777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-27-2003 08:40 PM |
Grouping tracks for overall volume control | Mark_Knecht | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 11-08-2001 12:51 AM |
