Old 07-22-2008, 03:47 AM
Matt Darcy Matt Darcy is offline
Default Distorted / Tape / Valve Amp Vocals
While trying to put an idea down for a friend, he wanted a distorted or "driven" sound on his vocals. I read that the most common way to get and record this sound in pro-tools was with an analog tape recording plugin, or a valve amp based plugin.
I only managed to find one analog tape plugin for pro-tools LE, but it was $300 and no demo of it, or trial option, or samples, so I wasn't going to spend $300 on a chance it may be the right thing.
The only real valve amp plugins I could find was in guitar amp simulators, and I wasn't sure this was the right thing to do/use, so wasn't going to spend money on that yet.
the best way I achieved it was to actually plug a vocal mic into a vintage guitar valve amp (I know this is what the plugin does - but this was me make shifting, not finding the best way) and then mic up the guitar amp. It worked "ok" but sounded "distant" which is a problem I'm having when micing up guitar amps, or recording vocals in general (I have a post in genaral discusiion on it).
I'm happy to post the result I got from the valve amp to use as a bench mark against my comments above, but I'd really appriciate
a.) peoples thoughts on techniques on how to achieve that volcal distortion
b.) some example of what people have achieved and how they did it.
I'm happy to buy the tools to do it, but not being an experienced or advanced user I want to make sure I get the right tools for the job.
thanks
Old 07-22-2008, 06:39 AM
dougied dougied is offline
Default Check out this plugin
check out http://www.masseyplugins.com and his TapeHead or THC distortion one might work for ya. They are full version demos for free that are missing a couple things from the registered versions.
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 07-22-2008, 08:01 AM
Default
what a fantastic find, I'll have a play with these. and what great value to purchase the ones I like, big thank you for this.
Old 07-22-2008, 02:08 PM
Default
Anytime bud....... anytime. :)
MacBook Pro i7 2012
6GB RAM
Eleven Rack
Yamaha HS80s
Old 07-22-2008, 03:20 PM
Whiteyguitar Whiteyguitar is offline
Default
I was going to Suggest Massey but if you recently bought PT you will have recieved the Lite version of Izotope Trash, which has some good distortions for vocals another good one for free is Izotopes Vinyl.
Stay true to the sound,Less is best
Old 07-22-2008, 05:01 PM
ultrajoebot ultrajoebot is offline
Default
I've also had good luck with Amplitube 2, again going more for a guitar amp modeling type of sound. I think there's a demo of it out there somewhere.
Old 07-22-2008, 05:09 PM
pgripp pgripp is offline
Default
Try this for fun (and for free!)
a) Insert free Digi Compressor on vocal track
b) Set to "Hard Limit"
c) Pull down threshold for appropriate crunch.
Old 07-23-2008, 01:13 AM
Default
more diverse replies, excellent, all very welcome and appriciated.
Old 08-21-2008, 07:59 AM
dopewerewolf dopewerewolf is offline
Default vocals
Try a crappy microphone. Not the most pro-level approach, but I find it works really well. I often record vocals with two mics simultaneously. I use a nice mic to capture a clean vocal and an old 70's tape recorder mic that has some nice warm distortion built in. Then I mix the two takes to get the appropriate amount of clarity/distortion.
Using HEAT, DUY Valve and digi Reel Tape Raoul23 Windows 3 07-11-2011 06:15 PM
ReelTape vs. McDSP AC vs. DUY Valve/Tape SoundReplay Pro Tools TDM Systems (Mac) 12 03-26-2009 05:02 PM
PC equivalents for DUY Tape, Valve & McDSP AC2 rlcowa@work2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-08-2005 11:40 AM
DuY Tape / Valve experiences? Felix Tips & Tricks 2 02-14-2001 12:52 AM
duy valve/tape fidelman Pro Tools TDM Systems (Mac) 4 01-24-2000 04:37 PM
