Old 01-27-2005, 03:46 PM
1m1 1m1 is offline
Default Importing tracks and disk allocation issue
In OS 9 versions of Pro Tools, when importing tracks from another session, the imported tracks would retain the disk allocation assignment that existed in the source session.
Ever since OS X versions of Pro Tools, the disk allocation of imported tracks defaults to the same disk that the session file resides on.
Anyone know of a way to work around this so that the original disk allocation is retained?
Old 01-28-2005, 11:57 AM
MoreMeintheMonitors MoreMeintheMonitors is offline
Default Re: Importing tracks and disk allocation issue
Are you possibly having to convert audio files during import? If so, it will typically default to the audio files folder for the current session to save the converted file. Just choose the original folder when doing the conversion.
Old 01-28-2005, 12:03 PM
FajitaTone FajitaTone is offline
Check Setups>Preferences...>Operation Is there a check box in the Automatically Copy Files on Import?
Ray Trujillo
Freelance Audio Engineer
Old 01-28-2005, 05:46 PM
1m1 1m1 is offline
The situation I'm referring to is when I import tracks that I want to record on from a template. I want the tracks to retain the disk allocation that I assign in the template. So no, I'm not actually importing any audio files, just empty tracks.
Working on film music, it's common for me to import the tracks into 30-45 different sessions and I have to remember to change the disk allocation in each session, otherwise the audio files don't end up where I want them.
Disk Allocation issue MorninStar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-22-2010 09:04 PM
Problems with importing tracks and disk allocation peter99 Pro Tools TDM Systems (Mac) 3 11-17-2009 08:55 AM
What goes where? Disk allocation issue... Artaxiad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-08-2005 01:54 AM
Updated PT / Disk allocation issue??... michael ryan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-04-2005 07:28 PM
6.2.3 not importing Disk Allocation Klangfarben Pro Tools TDM Systems (Mac) 0 03-05-2004 02:35 PM
