Re: Aux reverb track
How can you hear it dry on playback? I only want that reverb for the 'talent,' on the cue mix. |
Now that I think about it, MBOX 3 has a reverb in its own mixer. It might be worthwhile setting that up for the cue mix, that way you can keep LLM on and not have to futz around with Pro Tools. If I recall correctly, you can assign it to whatever stereo pair you want, so it should work fine if you want to send reverb only to outputs 3-4. Instead of using a send to Bus 3-4 on the reverb return track, remove the send and assign the reverb return's output to Bus 3-4. You'll want to solo-safe the reverb return track too, so you don't accidentally mute it when soloing something else.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
I will try this and post again tomorrow. Thanks for all of your excellent guidance. |
Host control only allows Pro Tools to control the first stereo mix; you're using the second one (outputs 3-4) for your cue mix. You can safely disable it if you do all your routing in PT. But if you plan to keep LLM and use the MBOX built-in reverb, you should not disable it.
Thanks again for all you help. |
#16
Re LLM, if your rig will track at the 64 buffer, you don't need LLM Since LLM was broken for a time(back in PT9) I just stopped wishing for it and tracked with the 64 buffer, and never had any issues. My new rig will work all day at 32 LLM is really more for a system that can't run a low buffer(underpowered computer, or maybe you need a last-minute overdub on a huge session that is taxing the limits of your system).
#17
Out of curiosity, what's the system requirement for a 32 buffer? My rig is Intel Core i7 930@ 2.80 GHz, 24 GB RAM, and a Samsung 840 Pro SSD. My session files are on a WD Caviar Black internal 2 GB HDD. Last edited by dg27; 02-24-2015 at 05:42 PM. Reason: typo |
#18
I run HD/Native in my setup. It was installed in an i7 950 rig, not to different from yours(only 12GB of RAM though). 32 buffer was available, but I never tried to actually use it. In my quest to move to 11(for the 64 bit benefit), the old rig never lived up to its performance in 10, so I held off and saved my pennies. 4 months ago I built a "budget" 6 core with some good eBay scores and made an i7 3930K/X79 rig with 32GB of RAM(the single most expensive part) and runs the "bejesus" out of 11. It never recurred to me to try the 32 buffer until I had a 70+ track session nearly mixed, with a boatload of plugins, including a bunch of UAD stuff, which all has over 1100 samples of latency. Suddenly the artist decides he needs to record another vocal part and I'm looking at the screen all the plugins and the latency and going cross-eyed thinking of all the plugins I need to disable for latency....Then I decided, "what the hey, let's see what happens"? Set the 32 buffer(left every plugin going, including 9 amp sims) hit record and he sang his new part. Stopped a few times for punches and quick edits and finished up without a single hiccup. Imagine the stupid grin I had
#19
Great story--thanks for sharing.
Hearing Reverb AUX Track | RokVox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 06-08-2012 04:13 AM |
Samples delay on Reverb Aux track? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-11-2012 02:10 AM |
Can't hear the reverb on the aux track | debby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 08-02-2010 10:05 AM |
Want to use the infinite reverb on it's own track? | Sean L | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-27-2009 04:05 PM |
Vocals: Reverb v.s. Track Stacking. | Mr. Nizzle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-07-2002 11:02 AM |
