Old 10-31-2013, 05:21 PM
fsavell fsavell is offline
Default Pan Automation Bug
Having a really weird occurrence with Pan Automation not being followed correctly.
In fact its very strange behaviour, where-by the track will slowly pan back to its original position before the first automation break point. Have thoroughly checked that there is no other automation on busses or masters.
The drifting can be proven to be a bug, by just by clicking on the pan pot, where it suddenly snaps back to the correct automation position, but then begins to drift almost straight away.
Can't find an easy way to recreate this, it just started happening in two completely different mix sessions.
Anyone else seeing this?
Forrester
PT11.02 HDX2, MacOSX10.8.4, MacPro 12-core
Old 11-01-2013, 02:55 AM
joachim's Avatar
joachim joachim is offline
Default Re: Pan Automation Bug 11.02
Can you post a screenshot of the edit window and the track, with track view set to pan ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 11-01-2013, 04:29 AM
Drew Mazurek's Avatar
Better yet, post the session file so someone can confirm.
www.drewmazurek.com
Old 11-11-2013, 06:52 PM
Here's a session that displays the issue.
https://www.yousendit.com/download/O...Y3kwVW5xYk1UQw
If I click to the left of the automation break point, the Sine tone is correctly panned, same if I click the play cursor to after the break point, it is heard correctly to the right.
However, if I play the session, the Sine tone is played incorrectly, erratically panned down the centre and can be "reset" to its correct automated position by clicking on the Pan fader, but it will then continue to drift. Please let me know if you see the same issue.
Forrester
PT11.02 HDX2 OSX10.8.4
Old 11-12-2013, 03:21 AM
mhmh mhmh is offline
Same here, obviously a bug, bad one.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 11-12-2013, 03:26 AM
But.. after playing around with the breakpoints (delete one, put it back etc.) everything works fine.
www.3-p.de
www.imglashaus.de
Old 11-12-2013, 04:21 AM
joachim's Avatar
Totally weird.
In that session, new automation 100% left, gave something like 50%/50% on the Aux1 indicator, and varying.
With the track "pan error" set to "samples", not "ticks", everything was normal.
After that, with the track set back to ticks again, everything was also normal.
Kind of a "reset".
Old 04-05-2014, 07:15 AM
mickelini's Avatar
mickelini mickelini is offline
I just started using PT11 (11.1.2) and this bug still exists. The above fix works.
Old 08-31-2015, 07:49 AM
TerryKack TerryKack is offline
The bug still exists in 11.3.1, which just cost me a couple of hours until I discovered this page. The fix also works which was a great relief.
Old 10-25-2015, 09:19 AM
Leon550 Leon550 is offline
I just got this bug in 12.2.1. The fix still works.
Can't turn off capture automation on the automation panel tandem Post - Surround - Video 0 07-16-2014 09:36 PM
MIDI Automation to Audio Track Automation BBKBB Pro Tools 10 6 11-28-2012 01:56 PM
Convert MIDI automation to audio automation jnash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2010 03:28 PM
automation issues (re-writing automation when it shouldn't) revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 02:41 PM
Automation Quirk...I didn't Write any Automation!! a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-20-2005 10:34 AM
