Old 12-15-2019, 09:18 AM
secutanudu secutanudu is offline
Default Automatic "jump to"
Is there any way to set up a point in a session to have playback automatically jump to a particular marker?
Here's the use case:
I am working on a song where one of the verses has two parts (part A and part B). I am toying with the idea of removing part A. I could easily do this by deleting it, and shifting the rest of the session backwards.
But, as a temporary test, I'd love to be able to put a marker at the beginning of part A. When playback hit this marker., it would be programmed to jump to the beginning of part B, which would allow me to audition this change before I make it.
I know I could click my second marker mid-playback at the right moment to simulate this, but I was hoping it was able to be automated.
Any ideas? Thanks!
Old 12-15-2019, 09:45 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Automatic "jump to"
I don't think you can automate it, but you could open the Markers Dialogue box (Ctrl+Num5) and easily click between the two instead of trying to do it in the Marker Timeline.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-15-2019, 09:50 AM
john1192 john1192 is offline
could you use Shuffle Mode to place the different sections in whichever order you choose .. Edit Groups might also get you there ..
or something like this From Logic Pro X .. see pic .. Use Alternatives for Different Arrangements
File Type: jpg Screen Shot 2019-12-15 at 9.48.41 AM.jpg (57.0 KB, 0 views)
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 12-15-2019, 10:53 AM
Southsidemusic's Avatar
Doubt he knows about that as he is on Windows.
I would just make 2 arrangements and listen to which one sounds best! Songwriting and producing is not a race and should grow naturally and taken the time to get the best and having 2 complete arrangements is the way I would go.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-15-2019, 12:19 PM
does not matter whether mac or windows .. it was a picture for "Feature" Reference in a DAW ... something Pro Tools does NOT have .. this type thing ... other than Shuffle mode ..
sorry if i confused You
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 12-16-2019, 08:06 AM
Indeed! I save the session as is. Then make changes and save again as its own session. This would be a great feature(and I believe Studio One has it).
Another option is to bounce to a new track, solo the new track and chop/rearrange so you can get an idea, without chopping up everything
Old 12-17-2019, 08:10 AM
No way to automatically "jump to", but you can playlist it, make your edits, and switch playlists to compare. Note that automation will follow the edit (assuming automation follows edit is enabled) but will not follow the playlist switch. If I need quick comparisons between two edited versions that's usually what I do.
Ability to quickly switch between session versions would be a very nice feature for sure.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
When changing tempo - the grid do "jump" some bars senghor Pro Tools 2018 5 09-19-2018 12:05 PM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
how to disable automatic "fade in" when starting Playback (this 12.7) Franklyn Pro Tools 12 3 01-21-2017 02:02 PM
Fader "jump out" DanielZ Pro Tools 10 6 12-04-2016 10:51 AM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
