Feature Request?
Is there a way to copy plugins from one channel to another? Like option dragging? If not then i think the copy settings command should do it if you're copying from a plug onto an empty insert slot. make sense? I will set up one gtr with an SSL channel for example and want use it as a starting point for the next gtr and this save a lot of time.
thanks, Drew |
Re: Feature Request?
Drew, this is an idea that I had requested from Digi when I first got my D-Control. It makes sense that there should be a non-mouse way to initiate additional copies of existing plug-in assignments. While you cannot (as of yet) do exactly what you are asking, you can open a plug in on another channel and copy the settings of the first plug in into your new plug in (assuming, of course, you are using the identical plug in on both channels).
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate |
yeah, I've totally got the Shift/Command/Select to copy and Shift/Command/BMP to paste in my workflow already. All they'd have to do is make it so that when you paste on an empty insert it would be the equivalent of Option drag.
This is a great idea!
feature request | Bryan Cook | Pro Tools TDM Systems (Mac) | 2 | 10-03-2008 01:08 AM |
New Feature Request | mtung | ICON & C|24 | 9 | 04-27-2007 05:10 PM |
Feature/Bug Fix request. | Sonsey | Post - Surround - Video | 0 | 03-30-2007 06:39 AM |
New (Old?) feature request | RandallYoung | Pro Tools TDM Systems (Mac) | 3 | 10-21-2006 12:05 PM |
Feature request!!! | wheresmyfroggy | Pro Tools TDM Systems (Mac) | 4 | 05-10-2006 10:14 AM |
