Transfuser issue
I have an issue with Transfuser, it's like this...
When i load a patch into the tracklist of Transfuser, (doesn't matter if its drum, sliced or time-stretched) then record it in the internal recorder and try to drag & drop it to a stereo audio track, the bounced track doesnt match the sessions tempo. For example when i record a 4 bars in Transfuser with a session tempo of 95 bpm and drag & drop it into an audio track it makes it at about 5,1 bars long. Untill now I tried fixing it just with the time compression tool, but it doesnt always sound so good. I'm running PT 8LE currently, but I also have a system still with 7.4, where this doenst seem to happen. Anyone else ran in to the same problem? Digi any idea? |
Re: Transfuser issue
I work with amazing people who do incredible things. Founder of the Expert Sites. |
It's set a tick
filosofem |
I´ve got the same problem...
Have you solved It? |
I think this is a technical issue for some PT8 users who use Transfuser.
I double checked it with my 7.4 system where this does not occur. I don't use Transfuser that much, and if I do I just draw it in the Midi Editor. But the drag & drop from the internal recorder makes things a hell lot easier |
Could it be made as a plugin stand alone application in the future, as an option, as this may help with any future compatability issues as they arise in the future as a workaround. It may also be helpful for slower systems and make the plugin more marketable as it would expand it's usability.
BTW I ordered transfuser and look forwards to unlocking it's potential when it arrives in the store where I used to work.
Routing Audio Out of Transfuser Issue | DonaldM | Virtual Instruments | 8 | 03-07-2014 08:33 AM |
Transfuser GUI Issue | RokVox | Virtual Instruments | 5 | 01-23-2012 09:54 PM |
Transfuser/Axiom Transport issue | psi777 | Virtual Instruments | 0 | 02-04-2009 10:28 AM |
Transfuser Midi CC Issue | studiom | Virtual Instruments | 3 | 12-27-2008 08:41 AM |
Major issue with Transfuser | Compression Records | Virtual Instruments | 3 | 10-22-2008 02:42 PM |
