Old 04-15-2003, 09:13 AM
denbee denbee is offline
Default bounce qt midi to disk
In Pro Tools Free we have midi tracks using quicktime midi. Is there a way to bounce them do disk or do I need to take the files to Pro Tools LE.
Old 04-15-2003, 06:14 PM
M.Brane M.Brane is offline
Default Re: bounce qt midi to disk
In order to get QTI to be audible on a bounce you'll have to record 'em to an audio track. You can do this by patching your output to your input. You'll have to nudge the tracks into place because of the latency.
Old 04-16-2003, 03:30 PM
Fletch M. Fletch Fletch M. Fletch is offline
how do you patch midi into an audio file? I have a quicktime midi track and there seems no way to patch the sounds generated by quicktime to an audio track?
Old 04-16-2003, 06:13 PM
By patching I mean physically connecting the output to the input so you can record the MIDI sounds to an audio track(s).
Does that make sense? [img]images/icons/grin.gif[/img]
Old 04-23-2003, 09:57 AM
Ooops been away a while. Do you mean actually plug a cable from my output back in to my input, the lo tech way? hahaha. I did this as a work around a while ago, but can you actually patch from a midi track to an audio track in PTF? keeping it all internal/digital? I guess not. With soft synth programs can the be patched direct or do you have use the lo tech way? thanks for your help.
Old 04-23-2003, 02:22 PM
mike connelly mike connelly is offline
This probably won't help much, but FYI if you play back a midi file using the quicktime player, you can save it as an audio file.
Old 04-23-2003, 08:09 PM
Does it give you a choice on file type, or does it automatically give you a 16/44.1 aiff?
HTML code is On
How To Bounce Midi Tracks to Disk? Duke2489 MIDI 3 11-11-2004 06:11 PM
Can you bounce a MIDI track to disk? Funkmaster69 Tips & Tricks 14 03-19-2004 07:50 AM
MIDI doesnt bounce to disk pingosimon Digidesign Hardware & Software 4 10-30-2003 09:29 AM
How can I Bounce to disk a midi track? PJN Digidesign Hardware & Software 3 02-16-2002 11:19 AM
MIDI and Bounce to Disk FUMoney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-25-2002 01:24 AM
