Old 04-21-2019, 01:16 PM
trackone trackone is offline
Default A/B Two Tracks
Is there a way to A/B two tracks in Pro Tools? I am not talking about using the X-Or with Solo. I need to reverse the mutes on two track to listen in the context of a mix. The tracks are duplicates, but processed differently. Maybe I am looking at it the wrong way, but being able to reverse the mutes would make this real easy.
Old 04-21-2019, 01:26 PM
amagras amagras is offline
Default Re: A/B Two Tracks
Select both tracks, solo one, then press Shift+S or mute one and press Shift+M
amagrasmusic.com
Old 04-21-2019, 01:57 PM
Thanks, that worked. Couldn't use Solo for this but the Shift M worked for reversing the Mutes. I thought I had tried this but I see I did not have the tracks selected correctly. I see that the clips themselves must be selected, not just the tracks.
Old 04-22-2019, 02:10 PM
drewbixmusic drewbixmusic is offline
Somewhat related, the plugin sample magic AB is an affordable and convenient A/B for reference tracks and you can store the reference files in it as a preset. I recommend setting ref tracks to like -15db so you’re not smashing your mix buss to match loudness of red tracks.
Old 04-23-2019, 08:42 AM
midnightrambler midnightrambler is online now
Here's an alternative method that I always use. Don't know how clear it is from this screengrab :http://duc.avid.com/attachment.php?a...1&d=1556033759
- Create 2 tracks, each with mix1 and mix2 on
- Send output of mix1 to bus x
- Select input of mix2 to bus x
- Use "I" button (input monitor) on mix2 to compare 2 mixes in real time. Or, as an alternative, put mix2 track into record ready and use "alt-k" to flick between 2 mixes.
This probably sounds like a faff, bit it isn't really, especially if you have a RTD track in input anyway. I'm always comparing the mix I have now with where I was say, an hour ago, or last night, or last week, or last year. (Etc)
Old 04-24-2019, 05:16 PM
I have a print track set up in my template and I do use this quite a bit with the Input selector, but I mostly use the X-Or option on Solo to A/B between two stereo mixes. However, the Shift M is really what I was looking for. In this situation I was not comparing two mixes. I had a duplicate vocal on another track. One vocal had some tuning corrections and processing slightly different from the other vocal track. I wanted to A/B them within the context of the other tracks.
Old 04-24-2019, 06:14 PM
Top Jimmy's Avatar
Is Nugen's AB Assist still free for Pro Tools users?
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 04-25-2019, 02:05 AM
Ha yes makes sense. I read "A/B two tracks" in your original post as "A/B two-track", my fault for not reading correctly
No audio in frozen tracks after export selected tracks to new session PierrevC Pro Tools 2018 4 11-14-2018 03:33 PM
OPEN WITH TRACKS INACTIVE???---snow leopard is biting my foot (& tracks) stormmusic Post - Surround - Video 2 10-09-2009 04:43 PM
Instrument tracks VS Aux tracks+MIDI tracks mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-03-2006 04:08 PM
How many Megs does a 4 minute song with maybe 3 stereo tracks/13 mono tracks take up? Sergeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-04-2002 02:31 PM
Would the Line 6 POD pro SPDIF outs make the guit. tracks MIDI tracks? Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-06-2000 08:40 AM
