Mastering Tips
I was wondering what tips and techniques you guys could recomment for mastering in Pro Tools. I have recorded a few songs lately, but the volume always ends up being half of what I would like it to be in the final product.
Any suggestions to get it boosted?
Amo Audio Vancouver BC www.amoaudio.com |
Re: Mastering Tips
Best of Luck mastering Joel |
Re: Mastering Tips
"Any suggestions to get it boosted? "
First off, "mastering" doesn't equate to "boosting". Secondly, I'll let the legions of DUCers to fill you in on what to do to sound like crap, er, the major labels and commercial ready CDs...
OS 10.3.9 1.25 mhz single G4, 1.25GB RAM, Firewire & Internal recording drives, Nomad Factory plugins PT 6.4, 001, Motormix |
Re: Mastering Tips
JOEL, Thanks for the excellent suggestions. You have a talent for writing in a clear and helpful way.
Its confusing to read that certain authors perform the tasks you talk about while MIXING and yet others do these things while MASTERING. So far I haven't found any clear instructions that answer my following questions: 1- how to choose and use plugins (in PT why do you choose between those in the AudioSuite and those that appear as inserts)?, 2- what order to use them?,3-when to use them? In the general scheme of things, during Mixing and Mastering what is the sequence of steps after making a good recording? At the end of all this is this, where does the Master Fader comes into play, how do you mix to the final stereo track, and do you Normalize when Bouncing to disk? Sounds like I'm asking for the moon and if an outline is not possible perhaps you could make some reference suggestions. Thanks in advance.
Ray |
Re: Mastering Tips
1-go to Waves.com---click on support, then tips and tricks. Waves will give you the quick answers for compression, and plugin I deas.
2-Read the ProTools Manual 3 times and take notes... 3-go to digido.com and take notes You would use Audiosuite to have more CPU power, and you can use a plugin 100+ times with Audiosuite. When you keep plugins open in the inserts, this slows your system down, after you reach your CPU limit... [img]images/icons/cool.gif[/img]
I Seek the Holy Light... Isaiah 40:31 72 Strat with single 2-Blade pickup PTLE 10.3 LE 2-SSL Alpha Channels - 1 SSL G-Compressor Apogee Rosetta 200 - Z-Systems Opti-patch Lexicon MPX-G2 Guitar Processor - .003r Command 8 - Roland JV1000 + Triton Rack FOCAL TWIN 3way speakers + JBL Q108MK11 Bottom 2-52 jax MilSpeck Patch Bays 2-22" Apple Cinema Display's Allen & Heath 16ch Mixr **Currently = 11-1-12 2 CD's Released-1-2003-2-2012 Worship ROCK |
Re: Mastering Tips
If you're looking for a quick and easy method to master with relatively decent results, you could try T-Racks from IK Multimedia. I've had pretty decent results in the short time I've messed around with it. Comes as a standalone app or you can use the RTAS plugin on your master fader.
--- c
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff. |
Re: Mastering Tips
To give you meaningful suggestions, I think it would be good to know: (1) What kind of music are you working with? (2) What are you goals? Just to make the recordings louder? Do you feel they lack anything else at this point? (2) What plugins do you have? (3) What commercial products are you measuring your work against? For a better understanding of what mastering involves, how it differs from mixing, and lots of other great info, I would suggest buying a copy of Bob Katz’s book, Mastering Audio – the art and the science, available here: http://www.digido.com/ D |
Re: Mastering Tips
The best advice I can give is buy the Waves mastering suite. The manual is amazing and gives really great advice on how to use the plugins for different applications.
Yeah it's expensive compared to the alternatives but nothing else comes close. If you are serious about mastering it's the way to go IMHO. If you just want you mixes to be louder, put a limiter on your master fader. I would use L1 if you have it. If you are mixing in 24 bit don't forget to Dither to 16. Also like guitates said, go to waves.com, under support they have a lot of great tips and tricks. Hope that helps, Jason
2018 Mac Mini 3.2GHz 6-core, 32gig ram - OSX 13.4 - Protools Ultimate 2023.6.0 - HDX PCIE in Sonnet Thunderbolt 3 box - Apogee Symphony Mk1 |
Re: Mastering Tips
Sehvling EQ on the bottome, try -12 db slope at 44hz
Two passes of the L1. set realease at 10 Set the threshold so it's just 3 db below your peaks, set maximum at -.6 db, no dither, no quantizing, no shaping. second pass - Set the threshold so it's just 3 db below your peaks, set maximum at -.1 db, no dither, 16bit quantizing, ultra shaping . The above procedure gets my recordings as loud as a preofessional mastering studio without sounding squashed. |
Re: Mastering Tips
Two passes of the L1. set realease at 10 Set the threshold so it's just 3 db below your peaks, set maximum at -.6 db, no dither, no quantizing, no shaping. second pass - Set the threshold so it's just 3 db below your peaks, set maximum at -.1 db, no dither, 16bit quantizing, ultra shaping . The above procedure gets my recordings as loud as a professional mastering studio without sounding squashed. |
Mastering tips | timcrow420 | Pro Tools SE and Essential (Win) | 2 | 05-17-2012 05:32 PM |
MASTERING TIPS!!!! | woodbeatz | Tips & Tricks | 8 | 10-25-2004 12:41 AM |
Using the L2 And C4 For Mastering.. tips | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-14-2004 07:04 PM |
Tips on Mastering Hip-hop | Hardnox | Tips & Tricks | 18 | 07-27-2003 11:39 PM |
tips for mastering | Alberto Tarin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 03-08-2000 08:09 PM |
