#41
Re: 44.1 kHz vs. 48 kHz - why not use the higher?
It works in my post, but not the original post. I get a bad request with the OP's, i rewrote the link, and now it works.
#42
The text version is truncated. Without dither.
Try clicking here.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#43
That's pretty important and not theoretical. No circuit is perfect but the math explaining this theory is proven. It's the basis for all sampling. Perfect reconstruction is limited by filter design and aliasing components. But that does not prove the Nyquist math wrong. http://en.wikipedia.org/wiki/Samplin...ical_frequency Interesting that Nyquist's work was based on getting more signals to pass through a telegraph line per unit time in "Certain topics in Telegraph Transmission Theory (1928)" It is limited to twice the bandwidth of the channel. Shannon then picked up the work and developed the Information Theory.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
#44
That's actually only correct for capture and reproduction of mono, steady state tones. If music comprised nothing but unvarying sine waves, Nyquist would be all we'd need to know. As long as you didn't do anything to them in the digital domain.
#45
You DO NOT, nor have you ever, added dither when sample rate converting. you ONLY add dither when changing bit depth (which IS NOT sample rate conversion). Going from 48bit to 24bit, you add dither. Going from 48KHz to 44.1KHz you DO NOT. Reducing bit depth adds distortion which is why we add dither. Sample rate conversion DOES NOT add distortion and so there is no Dither added. This isn't open for discussion, it's scientific fact.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
#46
"Note: that with sufficient precision, this conversion process can be done without measurable error, but it requires considerably more precision than the 2:1 downsampling" Which is what I've been saying all along!!!! You don't try to divide 96KHz into 44.1K (what he is talking about when he is talking about the ratio). You Multiply 96KHz by 147, then divide by 320. When you do that, NO DISTORTION. Again, please stop trying to mislead people with novice DV forum babble and papers on consumer audio electronics that aren't even focusing on what we are talking about here. You are taking things you don't understand and trying to quote them as fact...
#47
James Moorer does a much better job of saying what I was trying to say (too simply) when I said "Coarser is coarser, finer is finer." I was picturing in my head a rough approximation of the principle Moorer outlines, but the way I said it is irrelevant under some circumstances. Moorer states it more precisely and relevantly in his article "New Audio Formats" as follows:
"We can talk about the error of the LSB* being a certain number of volts per Hertz. Given this definition, it is then simple arithmetic to note that the quantization error in volts per Hertz is smaller at higher sampling rates, such as 88.2 and 96 kHz, than at 44.1 and 48 kHz. All processing, such as equalization or dynamics, will share this lowering of the error due to quantization." *Least Significant Bit I've demonstrated this several times to my own satisfaction by upsampling material from 44.1 to 96 kHz, processing it with EQ or NR whatever, then downsampling it back to 44.1. This is for circumstances where very heavy processing was required, such that ugly artifacts were noticeable when processing at 44.1. I then did both null tests and listening comparison tests. The files almost null, of course. But the differences, while small, were unambiguous: the files processed at 96 kHz exhibited fewer unwanted artifacts, even after downsampling.
#48
OK, I have a question that maybe you guys can answer then. If a sample rate of 44.1KHz samples the source 44100 times per second, and 96K 96000 times per second, in recreating the sound, why wouldn't the higher sample rate sound better. I am just interested in the why's, because the Nyquist theory and half the sample rate all makes sense, but if your actually sampling more of the source it seems reasonable that the sound would be better.
Please if I'm way off base, correct me and I'll even delete the post if it's misleading. But I'm really interested in that end of the problem. |
#49
If I count eggs by the dozen or I count each egg will I get the same number?
But anyway, all converters run at 6mhz internally and just filter to whatever sample rate you want using the same techniques graphed at infinitewave. It's all SRC, usually with linear phase filters. And if the bit depth of the conversion is greater than the output, dither is used when truncating to the output format in a good implementation. This eliminates quantization error. Aliasing and imaging distortion and filter ringing are plotted at infinitewave and are also unavoidable tradeoffs, but less of a problem when the output rate is faster. This is also how nonlinear plugins avoid those artifacts. We need a good FAQ site to throw at people on this it's tiresome. |
#50
Now, other parts of the film process might (and can) benefit from having a 60 or 100 fps film speed, and that justifies it. But the "increase in quality" argument doesn't because there is none. A very smart man and inventor by the name of Dan Lavry has written white papers about this. He is also famous for designing one of the best sounding A/D and D/A converters in the world... at a price tag of $4500 per mono channel!!!! So, from a theoretical point of view, there is no audible difference between 44.1KHz and 96KHz in and of itself. But, the design of your converters and the type of processing you do to the audio while in the computer can sometimes sound better at a higher sampling rate. For example, pitch shifting sounds much better when you've recorded at 96KHz compared to 44.1 or 48KHz. That means something like Autotune or Melodyne will sound a little more natural and have a little less "artifacts" at 96KHz. Certain other plugins, like reverbs as described earlier, can be effected by the higher sampling rate. But remember, the sampling rate is nothing more than a strobe. It's like sitting in a room with a strobe light on. If you increase the speed of the strobe eventually you won't notice the strobe any more and it will appear as though the light is just "on". Fluorescent lightbulbs do this. If you record a fluorescent lightbulb in slow motion you'll notice that it turns off and on 60 times every second. But to us it just looks like it is "on" because our eyes and brain only take 18-20 snapshots per second. Once the Stobe goes faster than around 20 times per second, the light will appear to stay on even though it isn't. Our hearing can only hear up to around 18~22KHz and as you get older that drops, with most people in their 70's not being able to hear anything about 12~14KHz or lower. So, 22KHz is the upper most extreme any human can hear... so a sampling rate of 44KHz will be sufficient. But like I said, there are other factors at play, like the filter used at Nyquist and certain types of DSP that can have a noticeable effect on the Audible band even at higher sampling rates.
going higher than 10.6.3 | viaspiaggia | Post - Surround - Video | 2 | 06-23-2011 04:41 AM |
Can I get mp3.dll from 6.7 or higher? | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-13-2006 01:54 PM |
Anyone running higher than OS 10.3.4 with 001? | duderonomi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-15-2005 07:59 PM |
Anyone use JAM v.2.6 with OS 9.1 or higher?? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-21-2002 09:38 AM |
Higher Gain | Tommyboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-22-2000 06:48 AM |
