SDII / OS8
So, if you run 2.82 on OS8, what will be the telltail signs of "non-compatibility"? What would I gain with 2.83?
Re: SDII / OS8
Sound Designer 2.82 installation/deauthorization will not work on OS8.0. The workaround is to install and expand/deauthorize Sound Designer on a non OS8.0 system, and then copy it over to the OS8.0 system. Or upgrade to 2.83 for OS8.0 compatibility.
This pretty much goes for all copy protected software that came out before OS8 did for all companies The only gain is OS8 compatiblity. If you would like to order this update, please fax your VISA, Mastercard, or AMEX card number, the name on the card, and the expiration date to 650-856-4275 Or you can mail a check written on a USA bank for $49.00 plus tax to the following: Digidesign Customer Support 3401-A Hillview Ave. Palo Alto, CA 94304 USA Or fill out the order form that was mailed to all registered users in early April. If Sound Designer was installed prior to OS8, you will not have any problems until you deauthorize. OS8 will cause the loss of installs if you try to authorize Sound Desinger onto an OS8 system. -tm- |
sdII-pt/mac is not sdII-pt/window | chris.d | Pro Tools TDM Systems (Mac) | 15 | 07-03-2003 12:10 AM |
sdII-pt/mac is not sdII-pt/window | chris.d | Pro Tools TDM Systems (Win) | 3 | 07-01-2003 08:09 AM |
AIf .wav and SDII | Dale-c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-27-2003 11:13 AM |
SDII user questions and anyone with SDII for sale? | Dadulas23 | Digidesign Hardware & Software | 6 | 02-05-2003 11:32 PM |
5.1 & SDII | Larry Tamblyn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-06-2001 09:05 AM |
