subtitles to regions
Hi!
Is there a tool to convert subtitles to something like regions (Midi or dummy regions) ? This is only to visually see where there is spoken word in the timeline. I found this tool to convert srt to midi markers but markers is not what I want. https://en.editingtools.io/marker/ Thanks!! |
Re: subtitles to regions
Regards, Mark
Mark Franken, MPSE Dialogue editor/supervisor IMDb Creator of 'EDI' applications for sound post editors www.soundsinsync.com |
Thanks for clarifying that. Wasn’t sure of the OP’s file format.
Thanks for the info!
I was hoping for a bare-bones solution, I don't need all the functions of EdiCue or Edipromt, while they seem great apps. |
Pete Gates' PG PT app might be able to help?
Not quite unfortunately. I do need to increase the range of import options, been requested a lot, need it myself!
Pete |
Hi Pete!
Nice to have you here now! I was actually examining PGPTSession when your reply popped up :) It would be great if you could implement importing srt files. I work in foreign language dubbing and while the recording of lines is quite similar to ADR, the pre-production is very different (the whole movie is "ADRed" ). In ADR, usually a sound engineer prepares the session using Pro Tools and documents are generated based on this session thanks to apps like yours. In foreign language dubbing, the production team does not use pro Tools but specialized software to spot the lines and generate the documentation (scripts, cue sheets, etc) Maybe the simplest way to represent time-based text is the srt format although it lacks additional data. I plan to use whisperAI https://github.com/openai/whisper to generate a "draft" srt file from the original dialog stem of a movie. The speech detection accuracy is not important but the timing of the phrases would be super-useful for bringing into Pro Tools a visual overview of where the dialogue is located in the timeline. In the meantime I will try to study the Pro Tools session text export format and see if I can hack a script to transform subtitles to that format. Cheers |
I am in the same boat as OP - I do have Edicue though - but coped for years with a simple Filemaker database and script to import .srt, which can then be exported as xlsx/csv after cleaning up some elements - like making sure there are not 2 lines for 2 characters on the same subtitle block.
Mac 16 Core 7,1 -Os 10.15.7 - 96 gb Ram - Pro Tools 2022.6 Ultimate in 5 suites - MTRX Studio -S6 26-5-D - Sync HD - Video Satelite (Symphony 2022.5, AJA Kona 3g) Pro Protools 2022.6 Vanilla in 21 x Recording and Edit suites. Mac 6,1 Mac Mini, Mac Mini M1, Mac Studio Pro, Mac Studio Max Mediacomposer 2021.12 on AJA Kona 3g / XT I/O x 3 suites. Multiple Avid S1, S3 & Docks |
If you’re doing dubbing there’s only one tool you should be using and that’s VoiceQ.
Also, this will import SRT files into Oro Tools. https://non-lethal-applications.com/...aster-2-editor Last edited by its2loud; 04-24-2023 at 06:18 AM. |
duplicating midi/inst regions auto-joins regions? | WestphalMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-10-2009 09:44 PM |
realtime pitch (without time correction) in PT8? + putting audio regions into regions | fonografist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-07-2008 11:15 AM |
Audio regions not viewable in regions list | stormpro | Pro Tools TDM Systems (Mac) | 5 | 12-31-2006 09:08 PM |
Regions madness! 6 edits creates 4200 regions!? | crizdee | Pro Tools TDM Systems (Mac) | 8 | 04-18-2005 10:21 AM |
Del unused Regions bombed. now I'm missing regions | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-19-2004 03:33 PM |
