Old 05-27-2021, 08:05 AM
CraftWW CraftWW is offline
Default EuControl won't save my locked fader assignments?
When I return to a saved session or a template EuCon lost my assignments
of the saved faders.
During the session it works but after loading the session again or another one they're lost ? Did anyone have the same issue?
Old 05-27-2021, 03:14 PM
bewk's Avatar
bewk bewk is offline
Default Re: EuControl won´t save my locked fader assignments?
Have you stored the assignments you've selected as a layout? You can make assignments but to make them recallable they must be stored as a layout first.
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA
• PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD)
• Avid Dock, iPad 7th gen & EuCon 2023.11
• DADman/Eucon monitoring
• BSS (DAN + 100), QSC DCA 1644, JBL 7 Series
• MTRX Studio // 7.1.4
www.quesound.com
Old 06-02-2021, 08:51 AM
Thanks for the quick response.
But I mean the lock of the otherwise auto-generated fader assignements, not the user switchable layouts.
I used to do a template session in pro tools and configure locked faders on one S1 and they usually returned for every session generated from that template.
Or am I missing the point?
Old 06-02-2021, 09:46 AM
BScout BScout is offline
Default Re: EuControl won't save my locked fader assignments?
You have to save it as a layout (store in Layouts) in order for it to recall with a session. Saving layouts is not only for switching layouts. It is for any case that you want your fader assignments to stay with the session. Otherwise they are discarded when you close the session.
Old 06-04-2021, 01:55 AM
Alrighty. Will try. Thanks you very much.
Assignments in EuControl not working Cryos Avid S1, S3, Dock and Control App 6 07-14-2018 03:15 PM
Failure to save Bus assignments SpacekidX Pro Tools | Intro Discussion 1 06-18-2016 12:28 PM
[FR] - fader re-assigning and eucontrol improvements Joris de Man Artist Series 0 01-03-2011 11:24 AM
Can i save non defaut controller assignments for Xpand! The Dougfather MIDI 4 03-09-2008 06:52 PM
Strike & Master fader locked at max 77pro Virtual Instruments 10 03-05-2008 07:12 PM
