10.3 Mountain Lion Nightmare with HDX
Looking for any wisdom out there...
Nehalem 8 core x 2.26 with HDX. Worked flawlessly on Lion with 10.2. Upgraded to ML and 10.3, and I have NON-STOP 9171 and 9172 DAE errors. I'm recording a single vocal against a piano track. It is unusable right now. Anyone have advice? Repaired permissions, ran Diskwarrior. Buffer Size at 512. Tried 14, 8, 12 processors - all same effect. H e l p |
Re: 10.3 Mountain Lion Nightmare with HDX
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
I did a 'safe' uninstall....I'll try the full one.
Thanks guys, I typically get a new drive before I install a new system, but I got greedy for ML. |
Shouldn't be a problem since they're both qualified - but it is... I got a thread here on the subject... http://duc.avid.com/showthread.php?t=328101 |
I'm on 10.8.2 with no issues so far for a week.
I was getting error like you with 10.8.1 and PT 10.3 I had to repair permissions and delete all my PT preferences. Works since I did it
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1 - D-command 24- Trinnov Dmon6 |
Thanks!
Just did a 'clean' uninstall of PT, then a reinstall. Will report back... |
I'm torn between doing a fresh install of ML and 10.3 and *another* fresh install of Lion and 10.2.
I've got it on a SSD so I didn't have enough space for a partition to do a install. I got greedy. Any reports of from HDX users running 10.3 and ML successfully? |
I've had major issues with 10.8.2.
Every time I have one of these sandboxing errors, I get a 9171 error in Pro Tools: https://www.google.com/webhp?hl=en&t...4350d1cf0aed2f |
Thanks, Chris! This seems like it - it always felt like the crashes weren't dependent on how much load PT was taking.
But this doesn't affect everyone - my friend with a new 12-core just did an update (not clean install) to ML and 10.3 and hasn't had any problems. Did you do a clean install of ML? |
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION | DESVED | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-21-2013 03:18 PM |
lion -> mountain lion question | grant howarth | macOS | 3 | 05-01-2013 01:24 PM |
Lion or Mountain Lion for mid-2009 MBP with PT9 | miezurecords | macOS | 0 | 03-17-2013 12:38 AM |
Would you go from Snow Leopard to Lion (not Mountain Lion) if you could? | EricWillhelm | macOS | 9 | 01-11-2013 10:55 AM |
Downgrade from Mountain Lion to Lion | The golfer | macOS | 7 | 11-14-2012 05:53 AM |
