Protools 10 and 10.0.1 does not save input routing
I have a session that has the following problem
140 active Tracks, Some of them I want to switch "NO INPUT" Whenever I load this session again the old inputs are in again. The original session came from an other HD native. Because I have on my machine another In/Out configuration some In/Outs are greyed out. Those greyed out tracks are not possible to save to no input. There is a workaround when I save session first with inputs switched something else and after reopen then switched to no input. That works! Ok! Not a real problem. I am just wondering if someone has similar errors. Good, that it does not happen on my aux tracks. Otherwise my mix would be broken! Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
Re: Protools 10 and 10.0.1 does not save input routing
Ale,
This is a known bug. But you've successfully discovered the only known fix for it. It was discussed at length on this thread some time back: http://duc.avid.com/showthread.php?t=303229 Not really a total show stopper, so once we all figured out the solution, we just moved on. A bit annoying, but it's OK. Cheers Steve Bush www.music180.com/pros/5887 2 x Systems: MacPro 4.1 (Nehalem) 2.26 8 Core, OSX 10.6.8, PT10HD, 14 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O. |
Thanks Bushpig
Did not know this. Sorry for coming with an old issue I did a search before, but did not find anything. Ale
I am having this problem too. I recently received a project to mix from a friend and upon changing the inputs to (No Input) and saving.. when I reopen the project I get a message saying the same old thing about the inputs not being there that were on his rig even though I saved "No Input" on all those Tracks. Then it proceeds to somehow remember what his input settings were and puts them back to that greyed out. Not a huge deal, just annoying.
Workaround doesn't work for me... I assign existing IO to the 'bad' inputs, save the session, then save as a new one. In the new one, I assign NO Inputs and keep working. Next time I open the session, the 'bad' inputs are back.
Anyone else?
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
I am surprised they have still not fixed this. I have 10.3 and new system just setup this week and I have that issue.
Jan 2015 - same bug STILL HERE
PT HD 10_3_9 Mac 10.8.4 |
Is there a way to save or freeze Plugin I/O Routing? | dave911 | Pro Tools 10 | 3 | 03-16-2013 01:50 PM |
Can can you save bus settings/routing as a snapshot? | shnurgle | Pro Tools TDM Systems (Mac) | 10 | 04-30-2009 03:50 PM |
Routing input 5 from 002 to input 1 Amplitube Live | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-27-2004 12:56 AM |
Input Routing | The Weed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-26-2003 01:59 PM |
I/O Setup will not save Hardware Routing | florian sommer | Pro Tools TDM Systems (Mac) | 1 | 11-16-2003 11:12 PM |
