Dissapearing faders
Hi guys,
Is the current version of the editor compatible with OS 8 ?? When I move the pan faders the numbers are written over themselves and you can not adjust with precision. Greetings from Chile |
Re: Dissapearing faders
Cristian,
The editor appears to work well with OS8 with the exception of the graphical problem you describe. What causes it is having "system-wide platinum appearance" set in the MacOS appearance control panel. If you uncheck this and restart the problem will go away. Other than that I doubt you'll see any problems. -BM- |
Regions dissapearing - read this! | Zarabozo | Windows | 2 | 12-12-2011 01:02 AM |
Shortcuts dissapearing in win 7 | lapieuvre | Pro Tools M-Powered (Win) | 2 | 07-13-2010 08:00 AM |
Dissapearing Master out Meters. | WorkingEngineer | ProControl, Control|24, Command|8 | 2 | 12-04-2006 03:03 PM |
Dissapearing Folder | lampmusic | Pro Tools TDM Systems (Mac) | 0 | 08-29-2005 08:46 PM |
dissapearing transport | dfranko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2005 03:54 PM |
