Old 12-09-2014, 11:31 AM
LarsSlate LarsSlate is offline
Default Re: Euphonix midi ports
For the record I have tried everything on the web.
Clear the pref cache.
Clear the midi pref cache.
Uninstall Eucon.
Downgrade to earlier versions.
Installed latest 3.2.1 (not sure the exact of the top of my head)
Turned off App Nap (with mavericks I used the terminal app to do it)
MC has a static IP and my NIC has a static and its on its own network not the main LAN.
Aside from the lack of midi ports showing up it also locks up (Eucon) and if it does not lock up and still works the screen on the MC locks and shows the last app only even thought he controls may work.
There is a lot of lack of support in programs for this but you can make the MC work and do it jobs with some tweaks and time to setup, so that's why I bought it. But having the software buggy just makes this not worth it at all.
We are so used to a plug and play world and we should be. Avid please fix this or the Eucon protocol will die a slow death as we migrate to other vendors.
Old 12-10-2014, 12:27 AM
TabSel TabSel is offline
I'm thinking about returning the Artist Mix as basically only Eucon works, and it only is supported in Cubase.
HUI protocol doesn't work at all (no Midi I/O at all with Euphonix MIDI port), MCU protocol works partially only (no usability of the shift and knob set buttons, no MCU display Line 2), and this only with ONE application as there are no Euphonix MIDI ports 5-32)
So the unit really is useless with this kind of software.
Avid, are you listening? You don't answer to support inquiries, too? What are your further plans?
Old 11-18-2016, 01:05 PM
Neale Neale is offline
Still dealing with this. Avid has acknowledged the bug and says they're working on it, but 3 years to fix it?
Anyone else going through this pain in the butt?
ProTools 8.0.4 doesn't send MIDI to Yamaha S90 ES; midi out ports [Emulated] bbirney Pro Tools M-Powered (Win) 8 05-19-2018 06:58 PM
MIDI Virtual Ports not showing up in MIDI Controllers (8.0.5) emiliojazz Pro Tools M-Powered (Mac) 0 02-18-2013 12:03 PM
Three MIDI ports on DIGI 002R within MIDI studio Setup Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-18-2010 04:57 PM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
002R Midi Ports / Midi Time Stamping avatar9000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-20-2005 04:43 PM
