PT10 doesn't see 003 Interface
I'm having a problem with a new installation. Actually, everything has worked for the past few days and now (all of a sudden) PT10 doesn't register the Digi003 interface in the Setup-Playback Engine. The 003 interface shows up as a device in the Apple => Systems Preferences => Sound control panel. I can also get the Avid CoreAudiio Manager application to see the Digi003. But PT10 doesn't.
I did a reinstall of the current 002/003 drivers and PT10. No help. Again, all was working just fine, but now not at all. Any ideas? |
Re: PT10 Doesn't See Digi003 Interface
Found a solution, but its very weird. A few uninstalls and reinstalls, and a recreation of the I/O (.pio) files that map to the 18 I/O of the 003. Oh, and a disk permissions sweep in Disk Utility. Weird.
Interesting. I found I had to download drivers for the DIGI 003R when I got the new Mac. They didn't come with the PT 10.
Regards, Ty Ford |
Hi!.
I have the same problem you have. I am Spanish but I use a translator for English. Please can you help?. I need a solution for this problem, it is very important to me. Thanks |
Please, help me, I have the same problem. |
Do you can send me the "Digi003.pio" file ?
My mail is: [email protected] Thanks man. Do you can send me the "Digi003.pio" file ? My mail is: [email protected] |
My mail is: [email protected] Thanks man. |
The OP found a solution so if you have the same problem that will fix it. If not then I would not have piled onto a thread with a problem that seems the same but us not. You need to start by reading the "Help Us Help You--Read this before posting" link above on this web page and go through the standard troubleshooting and optimization steps there.
If you still have a problem after doing that we need a clear description of your setup and exactly what troubleshooting things you have tried. Darryl |
Re: PT10 doesn't see 003 Interface
How to use PT10 w/o Interface on Macbook Pro??? | foxg | macOS | 3 | 10-28-2012 01:41 PM |
Crossgarded PT10 to use in another audio interface | rebenky | Pro Tools M-Powered (Win) | 0 | 10-14-2012 09:01 PM |
PT10 without an interface | FishboyUK | Windows | 0 | 04-03-2012 10:55 AM |
interface with more inputs for PT9 and PT10 | DarylBham | General Discussion | 10 | 12-22-2011 09:29 AM |
the fIx to LATENCY!!-using a Focusrite 8i6 Interface & pt10 | shelbybrownjazz | Pro Tools 10 | 1 | 12-20-2011 04:55 PM |
