How to bus to Outputs 5-6?
I'm trying to buss a drum mix to a stereo aux channel outputting to 5 & 6 but there's no audio coming thru the Digi Snakes Outputs 5 & 6.
Am I missing something??
Armando |
Re: How to bus to Outputs 5-6?
Have you tried defaulting the output and bus IO? Is there activity/moving meters showing on the master fader (add one to see). Describe you setup, what interface, and computer, and post clear screenshots of the bus setup in the mixer window and of the output and bus IO pages. Start at the "help us help" you link up top of each DUC web page to see they type of information expected. |
Ok, my interface is a Digi 192 I/O and am using a Control 24.
I've got BFD 3 loaded in a session Instrument track and what I'm trying to do is send an independent stereo mix to two stereo monitors by the V-Drum kit out in a separate area. The first thing I did was create a Stereo Aux channel and bussed BFD to the Aux channel-Input Buss 1&2. I then set the output of that Aux channel to 5&6. I then connected the 5&6 Monitor Out snake fan out cables from the Control 24 to the inputs of the two monitors. When BFD is playing, you can see the audio signal displayed in the Aux channel and on the Bus Output Meters on the Control 24 but no audio is being sent out. I tried outputs 7&8 also but had the same results. I also tried Output channels 3&4 under Alt Monitor and this worked fine but I want an independent level send. Am I missing something here? A setting? I'm running Pro Tools HD 10. Thanks in advance!
Armando |
If nothing else you can confirm the pinout wiring of he snake with a continuity checker/multimeter. And/or put a hot signal gen sine wave on the output and probe the pinouts on the DB-25 connector with a AC voltmeter/multimeter to confirm it is there and then go find if its on any of the outputs on the snake. You've tested the other outputs 3/4 with the same monitors and monitor cables (from connecting extra cables from the snake) so you know they work? I'd do the above quick test first, but after that... again, did you default the IO? If you put a master fader on that output (5/6) what do you see? (in Pro Tools not the Control24, forget that for troubleshooting now). You have sends pre or post fader? Fader turned up? Again screenshot time... (ones I asked for before). Show us exactly what you are doing. Last edited by Darryl Ramm; 07-31-2016 at 01:30 PM. |
I appreciate the "troubleshooting" you're steering towards but I'm inclined to think this is a routing issue. I'm running a stereo session. Could that be the problem? Does the session need to be set up as a 5.1 session to have the other output channels available?
I haven't had the need to do any 5.1 work so..... I look forward to your ideas. Thanks!
Armando |
Nothing to do with 5.1.
My idea is you troubleshoot as suggested, and provide screenshots etc. Have you even defaulted IO yet? tested if the physical cable is contiguous? That's should be <10 minutes work. |
Ok after reading up on Chapter 8 Monitor section in the manual, I found that I needed to change the Stereo mode in Utilities from "Single" to "Multi". Since I have the second pair of monitors connected to monitor outputs 5&6, selecting 5.1 in the Monitoring section immediately sent the channels assigned to outputs 5&6 to the appropriate speakers. I can adjust the level via the channel's fader.
That's one solution. I believe the other solution would be a custom db25 to db25 w/specific fan out sending channels 1&2 to Control 24's Source input on male db25 and channel's 3 thru 8, as an example to any external sources as either XLR or 1/4" TRS plugs.
Armando |
Outputs configured in I/O setup not available to select as track sends/outputs | Stuart@YM | Pro Tools 12 | 5 | 03-21-2016 07:44 AM |
Amp outputs same level as Main outputs? | DonaldR | Eleven Rack | 0 | 02-07-2013 01:50 PM |
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! | italianguitar | Eleven Rack | 15 | 03-20-2012 01:57 PM |
Apogee Duet outputs better sounding than Digi002R outputs? | Pasz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-08-2010 02:19 AM |
please help on mirroring outputs 1-2 to s/pdif outputs! | ournature | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-13-2007 08:52 PM |
