Old 08-10-2017, 02:26 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Sound on Sound?
if it helps any , I use playlists and alternate takes/loop recording for this kind of drum editing
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB OS Windows 7 Ultimate
PT 18.1 Native through A&H Qu-32
Old 08-11-2017, 09:59 PM
Extreme Mixing Extreme Mixing is online now
Basically when you want to punch drums, you would have the drummer play exactly what he was playing on the previous track. So if there's a fill to a Kick drum and a crash on the downbeat, then that's what he should play. Then you will get the ring of the toms and the punch will just work. If you punch in to him just playing Kick Snare and hat, you will always have problems. Why? Well because you probably don't want the tight kit to just fade up under the other sounds.
And by the way, how would your "other DAW" know how long you would like this crossfade to be? Will it just feel it? You are using the wrong method to solve your problem. It won't work.
Steve Shepherd
Extreme Mixing
Old 08-16-2017, 01:33 PM
ChuckS ChuckS is offline
Originally Posted by Carl Lie View Post
Love to know the names of the "other DAWs". I own most of them and they all work like PT.
Mixbus has a feature called track layering which is distinct from takes. Opacity is an interesting concept.
Region Layers
Regions may be stacked on the same location in the timeline. This is called “layering”. Normally only the top region is heard; it covers the audio regions below it. However there are cases where the region below can be heard. One example is the top region’s fade-in or fade-out. Region fades operate as crossfades. If a region is stacked on top of another region, then the region underneath will audibly “fade out”, while the topmost region “fades in” across the length of the crossfade. The second way to hear a region below the topmost region is if the topmost region is not *opaque *(the Opaque flag can be turned off in the Region menu and/or the right-click Region context menu).
I would assume this is a feature of Ardour (the underlying DAW).
PT 2018.1 DP 9.51 VEP 6.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1709)
PT 2018.1 DP 9.51 VEP 6.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.3
Will Files - Re-Recording Mixer, Sound Supervisor and Sound Designer Tom Graham Avid Pro Mixing General Discussion 0 09-08-2014 01:16 PM
Mbox Pro 3 master volume knob initial adjust jumps from no sound to sound : | Focuret 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2012 05:45 PM
Audacity Sound, Reaper Sound, Pro Tools NO SOUND RoganX Pro Tools 10 3 03-18-2012 09:06 PM
MBox2Pro - Boot:No Sound; Disconnect/Reconnect Firewire: Get Sound; Why? mav9999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-23-2009 08:48 PM
Skywalker Sound (Lucasfilm) Supervising Sound Editor Interview HDFilmtools Pro Tools TDM Systems (Mac) 0 10-02-2008 03:12 PM
